We will now leave them off, unless stored on drive, and put them on in very extreme windy conditions.
LES
There must be a dometic fridge vent convention somewhere where all our covers have gone for their holidays.on the only night I did my dometic top cover disappeared, never to be seen again.
Tried that, darned sticky stuff difficult to get off. So I used Selotape Magic tape, just pulls off leaving no marks.My drive is in an exposed position, plenty of 60/70 mph gales straight off the sea this is winter. I don’t usually park my van there, but on the only night I did my dometic top cover disappeared, never to be seen again. That was despite taking care to ensure it was securely fitted. Cost of replacements, particularly in dark grey are ridiculous! In extremely windy conditions I might be tempted to use a bit of gaffer tape - belt & braces!
AFAIK I think that is wrong. It is to stop the fridge getting too warm paradoxically. In order to cool down an absorption fridge has to first warm up the gas in order to turn it into liquid. If it can't, because too much cold air is coming in from outside, it won't work and will start to get warm from the warmth inside the motorhome.I thought that the purpose of vent covers was to use them when it was cold outside to stop the fridge getting tooooo cold.
Am l right or wrong
I have the same issue with duck tape on my vents. What did you use to remove the marks please?Tried that, darned sticky stuff difficult to get off. So I used Selotape Magic tape, just pulls off leaving no marks.
I used both nonstickystuff, then I think just neat alcohol. The essence seems to be, loosen or moisten the goo, then just rub it off with a fairly ribbed cloth. Does that make sense to you? I really cannot remember the actual fluid that did the damage, but it did work easily when it did. And that was only a month ago in England! Oh dear, memory!!I have the same issue with duck tape on my vents. What did you use to remove the marks please?
Cheers.
Try WD40, it does remove most sticky stuff.I have the same issue with duck tape on my vents. What did you use to remove the marks please?
Cheers.
I bought the cheap white ones from Ebay and sprayed them with car paint. ! ?. Looks just the same.I also hesitated at the cost so made some fairly simply with a router and plywood, protected with a couple of coats of paint.
Evostick cleaner.I have the same issue with duck tape on my vents. What did you use to remove the marks please?
Cheers.
Brake or carb cleaner?I have the same issue with duck tape on my vents. What did you use to remove the marks please?
Cheers.
Always fitted here when van not in use -- to try to keep the mice out. Oh the joys of countryside living!
Do I understand this correctly now, in warmer climates the covers are fittedAFAIK I think that is wrong. It is to stop the fridge getting too warm paradoxically. In order to cool down an absorption fridge has to first warm up the gas in order to turn it into liquid. If it can't, because too much cold air is coming in from outside, it won't work and will start to get warm from the warmth inside the motorhome.
See here for an explanation
RTMWell confused here, some people leave them on all the time whilst others leave them off.
Does anyone know what is the correct thing to do for the fridge efficiency.
Thanks to all
I am not the only one who doesn't
