lugnutt
Hi Jim you can partialy flush the black tank with the grey if you are dumping into a manhole or grating as follows: dump all of the black then with the black valve still open lift the dump hose upwards so the open end is above the level of the tanks then open up the grey valve this will cauase the tanks to equalise then carefully drop the hose into the manhole or grating.
Regards Pat
thanks for all your input ....but mine has two outlets gray on drivers side and black onthe other side not linked is this just my rv or are all c class like mine?
