Ivory55
If you use gas bottles, flo gas have on offer 11kg propane delivered for £15.99.
But did you check for leaks at the thread with soapy water.I just used the same pipe as the calor gas propane and it's working ok .
same here, exactly the same fitting.Been using flogas for ages, same reg
Thanks op
Wow - hadn't realised that. In which case I'll get my order in now. That will benefit both me & FloGas, because I will be able to order future replacements two at a time.And the best bit with this deal is no exchange cylinders required![]()
with my local depot i find its usually the 19kg bottles they dont charge deposits for or the bigger ones . but gas deal , give it a try.Wow - hadn't realised that. In which case I'll get my order in now. That will benefit both me & FloGas, because I will be able to order future replacements two at a time.
They did CHANGE IT straight off but I did notice in time before I went off.I have both calor and flogas and the threads are identical, EXCEPT when you accidentally collect a fork lift cylinder, which are completely different but should have a BLACK top to the cylinder, the one I got did not have one, just red all over
Do either of you have a link?Ordered two, thank you op.And the best bit with this deal is no exchange cylinders required
The link now gives a 404 error (they've taken the page down). I've also ordered and paid for 2 cylinders so now it's wait and see if they honour the order or cancel and refund my money.
