- Sep 13, 2018
- 168
- 167
- elddis 105 2015
- before this it was in the 90 s
Hi Elddis 2015 Majestic The lights indicating a problem with the seat belts and also the airbag have been coming on on the dash, on then off but when I drive for over 100 miles then they go off and stay off for the duration of the journey What I understand from reading about this fairly common fault is to firstly look under the drivers seat or the passenger seat to locate the ECU which often has a loose connection I have looked under both seats and can not find any such thing to check Can it be located anywhere else on the vehicle? If it is not a loose connection what is the best way forward for this issue? I am aware that it would be a MOT failure which is due in a few weeks hence it must be cured soon and I am also nervous of the great expense some people incur with this problem Many Thanks
