FLASHING MAJESTIC LIGHTS (1 Viewer)
Sep 13, 2018
168
167
Ludlow, UK
elddis 105 2015
before this it was in the 90 s
Hi Elddis 2015 Majestic The lights indicating a problem with the seat belts and also the airbag have been coming on on the dash, on then off but when I drive for over 100 miles then they go off and stay off for the duration of the journey What I understand from reading about this fairly common fault is to firstly look under the drivers seat or the passenger seat to locate the ECU which often has a loose connection I have looked under both seats and can not find any such thing to check Can it be located anywhere else on the vehicle? If it is not a loose connection what is the best way forward for this issue? I am aware that it would be a MOT failure which is due in a few weeks hence it must be cured soon and I am also nervous of the great expense some people incur with this problem Many Thanks
5,418
55,257
hull
Laika Ecovip 300
Why the confusion, this is a known problem but can sometimes be caused by a poor connection at the plug which you disconnect if removing the seat, can alsobe caused by a faulty earth, hopefully that is the cause and not the need for a new dashboard, ours was done under warranty ina 2009 van some time ago.
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
there are no ECU's under the seats. the air bag ecu is on the right side of the passenger foot well, there are seat connectors under the seats that sometimes get snagged and woth checking
M-J
Jan 15, 2019
2,618
6,275
Cambridgeshire, UK
Rapido 986F
Getting there!
Because the post originally only said...
ā€˜Hi Elddis 2015 Majesticā€™
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
PS : remove the plastic Cab battery cover in the passenger footwell and front right you will see the airbag ecu. i would NOT wiggle any connectors while the battery is still connected , you could set off the airbags...
Riverbankannie
10,541
61,596
Bristol
IH 630 RL PVC
If it is a Fiat then there is information and photos of the ECU on this thread. Ours is 2015 van.
Jul 5, 2013
11,731
13,709
You do not say what base vehicle you have. If it a Fiat Ducato the Airbag ECU will be under the removable part of the cab floor where the battery is. Lift up the removable bit of the floor and it will be found at the front right side of the hole. My airbag warning light was on constantly a few months ago. There is a company in Liverpool called CrashData who you can send the ECU to and they will reflash it to clear the faults and return it. Costs about Ā£80 including postage.
Here is a pdf file with a photo of it and instructions.
  • Crash-data instructions.pdf
WESTY66
5,827
14,272
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
I think Elddis use the pug boxeršŸ‘ that said Iā€™ve seen a few Fiat fronts on the newer ones but the 2015 is a pug.
43,332
49,505
I think you're referring to the harness plug for the seat occupancy or seat belt sensors, not the ECU.... that should be under the dash or back of engine bay.
Check the under seat wiring for damage.
Jul 5, 2013
11,731
13,709
I think Elddis use the pug boxeršŸ‘ that said Iā€™ve seen a few Fiat fronts on the newer ones but the 2015 is a pug.View attachment 444798
Peugot built in the same factory as the Fiat. My guess will be it will in the same position and look the same, although the reference number may be different. Once you have that you can look it up on the CrashData website.
D
Sep 13, 2018
168
167
Ludlow, UK
elddis 105 2015
Thanks for good replies, will follow the pdf Peter thanks a lot
