DBK
While sitting under the awning using our tablets the availability of a USB charging point under the awning would be useful. But how best to add one? You can get waterproof USB charging sockets but these would mean drill a hole in the MH body so I looked at how this could be done without drilling any holes.
I recently fitted a couple of PC fans to the fridge. In the photo below you can see the in-line fuse holder and the black ground wire next to it which run to the fan controller. These were perfect for supplying the USB socket.
This was the socket I bought.
And here it is fitted.
The connections are made with two Wago 221-431 connectors.
This is how I plan to use it, just running the cable through the lower vent which can be removed and replaced in seconds.
I've ordered a couple of short (30cm) USB C extension cables which I'll fit once we park up and then we can connect longer charging cable when required.
So it isn't a truly external charging point but it is easily accessed from outside. Of course this will only work if your fridge vents are on the awning side.
