Firewire question / problem (1 Viewer)
2,338
10,141
I have an Sony 8 mm cam-corder and a stack of 8mm tapes I want to copy to DVD .. The camera has a firewire port.
I used to transfer onto the Mac.. (it had a firewire port).. but sadly it has gone belly up and not economical to repair ...
The Dell has USB and an eSata port .. but no firewire :Doh:
I've been Googling but as yet not found an easy way of doing it.. to be honest I don't think there is one ...
Any suggestions apart from throwing in the towel ..
pablomc
772
237
Durham
If your laptop has a PCMCIA slot or express slot you can buy a firewire card for it.
2,338
10,141
err.. just checked.. I don't have either slots ...
pablomc
772
237
Durham
USB to Express card adaptor.
[ame="http://www.amazon.co.uk/Startech-Usb-Express-Card-Adapter/dp/B0024OMS6E/ref=sr_1_8?ie=UTF8&qid=1329515218&sr=8-8"]USB to Express card adaptor[/ame]
Onderweg
Jul 17, 2008
508
240
Vlissingen, Holland
As of April 2008
I think your only option would be a firewire to usb adaptor.
FireWire is, depending on the type between 400 (6 pins) and 800 mpbs (9 pins)
But be careful, if your laptop has
USB 1.1 --> dont even try only 12 mbps,
USB 2.0 --> 480 mbps, could work but carefully check whether video transmission is supported (effective speed is often only 240)
USB 3.0 --> 5.000 mbps was promised. You can recognize Usb3 very easy, there is something blue in the connector (but in 2010 the effective speed was 400-420 mbps, sorry i am retired so dont have the new facts :RollEyes:) but USB3.0 will certainly do the trick
Only few laptops have an USB3.0 connection :cry:
Hope this is of some help
Regards
Paul and Ineke
2,338
10,141
You must surely have at least one spare slot.
If so, I've got a Firewire card I can lend you.
If you mean Express or PCMCIA slot.. no.. thanks for your offer
I have 3 x usb2 , 1x eSata socket , I x HDMI socket and a card reader slot
thanks, I had a look at these but can't determine if it would work ..
Is this any good?
Pete:Cool:
thanks Pete .. I honestly don't know
Regards
Paul and Ineke
thanks for the info..
will do some more reading on it ..
philw111
629
557
Moray Firth
Bessacarr 484
I have transferred 8mm video to digital using an "EasyCap USB video grabber". It has standard connections to the video camera at one end and a USB at the other - quality seems fine (as long as you aren't expecting HD).
The cables are on eBay for about a fiver - just search for EasyCap.
Phil
2,338
10,141
Phil
That looks interesting .. thanks Phil.. will look into this idea.. for £8 I'll give it a punt and see how it goes..
Re USB/Firewire adapters, there seems to be a lot of conflicting advice on the AV forums .. this is from a 'senior' member..
No you can't connect a firewire device to USB!
Firewire needs a constant transfer rate for video, but USB works on a burst rate transfer. Also the protocoles each use are different so hardware conversion would be needed.
Basically anybody selling a firewire to USB cable is selling a scam - they can't possibly work.
2,338
10,141
hi Jim I have a firewire card and software new in box for £8 if of any use.
thanks Roger .. but no slot to fit a firewire card on the lappy
2,338
10,141
EasyCap arrived yesterday..
I played with it yesterday and the only problem I have is sound quality .. it sounds like a badly tuned AM radio .. :Doh:
Did a bit of Googling and found several others had the same issue, the workaround is to use the lappy's Microphone jack socket connected directly to the CamCorder's (white) RCA socket..
After doing this it worked a treat .. can also use it just to view on the TV using the laptop HDMI output ..
I have video going back to the mid 90s.. so we spend several hours just re living the kids growing up, holidays in France and Spain.. great memories captured for ever on tape.. :Smile:
Now the big task... copying, editing and putting onto DVD ...
The ULead video editing software supplied looks ok.. if a bid dated.. but it runs ok on Windows7, haven't had a real play with it yet .. too busy viewing ..
