- May 12, 2019
- 545
- 794
- Autotrail Delaware
- Years Tugging - Newbie MHing
One of my main security concerns when travelling has been the ease of pricking the driver's side door lock, which will instantly unlock the vans central locking, just by inserting a screwdriver under the door handle - between the plastic and the door metal. Thus allowing entry at any time, most worrying when possibly sleeping in the van. I've tried the cable between the door handles as a method to secure the doors at night but it's so inconvenient because the cable interferes with the chair backs. Also tried a cable from the door to the seat base but also not the answer, the cable slips around on the door or base.
So I decided, after seeing several videos of the Heosafe Cab Door Security Locks they would be a better solution. Pricy at £150 a pair, but worth it for peace of mind. However, they require cutting of the Remus Blinds to actually attach them, the entire corner of the blinds casing needs to be trimmed to a specific shape, a permanent mod which (from the videos I have seen) does not leave a very attractive finish.
I was going to fit these Heosafe Cab Door Security Locks to my Autotrail tomorrow, but in the meantime (YouTube Addiction) I came across this on a YouTube channel 'Travel Time NI'.
A company in Germany is making a very simple plate that fixes over the driver's door lock (inside the door) and solves the 'pricking of the lock' problem. They also have a great little pair of 'chain' ties that pretty much do what the 'cable between the doors method' does but without the inconvenience. A bracket is fitted to an existing screw on the door and a chain is attached - which when the door is closed can then be hooked onto the seatbelt bracket of the van. Essentially stopping the door from being pulled open.
Here is a link to the plate for the lock and below it on the webpage the ties for the doors.
The Heosafe Locks will be on their way back to Amazon tomorrow! These, together with the (now widely known) motorcycle disc lock on the seat swivel measure will probably be the extent of my security mods for the cab. Unfortunately, the Hab door is not so easily secured as there is little space between the door frame and the cabinetry to fit a Had door lock such as the Fiama. Currently, I'm just using a torch to wedge the door handle to ensure the hab door is not openable from outside. But the hab door is still not secure when we leave the van.
Any ideas on that would be appreciated.
