Fiat ducato 2.8 oil in diesel fuel tank (1 Viewer)
Boringfrog
3,787
4,701
Low profile
I doubt it has, what makes you think it has?
Feb 22, 2011
10,480
21,997
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Well, never heard that one before ,!
Oil and filter change gone seriously wrong ?
Carried out by Mr Magoo
Boringfrog
3,787
4,701
Low profile
How do you know the fuel tank has all the engine oil in it, which is approximately 6ltrs, and when mixed with the diesel oil I'm not sure you could tell the difference?
C
candkandb
8
york
van
Engine misfiring badly. Checked fuel filter jet black. Drained fuel tank. Put new diesel in new filter. Started fine. Check today. Put pipe into a bottle more oil than fuel
Feb 22, 2011
10,480
21,997
Hymer B544 A Class
Since 2015
And before restarting, you topped up the oil where ?
That's really strange. There is no route for engine oil to get back to the fuel tank.
Can you rule out mischief by someone ?
Aug 26, 2008
4,890
26,734
B&NES
Van Conversion
since 2007
It sounds like a malicious prank. Do you have neighbours who object to your MH?
Boringfrog
3,787
4,701
Low profile
Don't know what you mean by "put pipe into a bottle"?
How much diesel did you fill the tank with?
Oct 7, 2015
740
3,591
newark
Swift escape 624
While I have no experience of this type engine I have had the same thing happen on larger vehicles, the cause was the fuel pump seal between engine and pump letting engine oil into the low pressure side of the fuel pump, cured by fuel pump renewal
Steve and Denise
5,579
15,289
Spalding LINCS
A Class Carthago
Since 2008
The pump on this van will be belt drive so no connection to crankcase.
Misterg
221
213
N Wales
Self build PVC
That sounds like 'diesel bug' due to water in fuel (yes, it will stop an engine)
(That's a diesel filter, btw, not an oil filter.)
Oil and diesel would mix. Are you seeing an oily looking fluid that the diesel floats on top of? If so, it's bacteria infested water and consistent with the clogged fuel filter.
There are chemical treatments that will kill the bug and remove the last traces of water (but it would be wise to remove as much water as possible first). Used to use something called Grotmar 71 on the boat seemed to work well.
Don't know where your oil went, sorry.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
If you had a problem with a worn engine could oil blow back past injectors into fuel tank taking account of ignition pressure within combustion chamber - diesel engines are compression ignition so some serious pressure within combustion chamber
Oct 7, 2015
740
3,591
newark
Swift escape 624
This was a major problem caused by bio fuel on engines that had fuel heaters or the tanks that it was stored in got warm it cost the company I worked for many hundreds of pounds for each vehicle to clean the systems and change filters and m-prop valves. bio fuel is not the best idea.
Lenny HB
56,115
164,339
On the coast in West Sussex
Carthago Compactline
Aren't Ducato fuel pumps electric?
May 7, 2016
7,933
13,486
West Sussex
Malibu Van 640 LE K
Since 2003
That filter looks very much like the dreaded diesel bug and when I got it in one of my boats it looked like a black oily sludge in both tanks. If it really is oil in the fuel tank the only source I can think of is engine oil being drawn into the diesel return system but I am no expert and I would be heading for a workshop.
Snowbird
11,818
22,348
Liverpool.
Fifth wheel.
Since 11-05-2000
Am with the diesel bug on this one. If your van has been parked up for any length of time with little fuel in it there is a strong chance of diesel bug. When parking the van up over winter or for any length of time it is always advisable to fill the fuel tank. This decreases the chance of condensation in the tank, which is the main cause of diesel bug.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
If the OP is losing engine oil and not burning or leaking oil the only way to get in tank is via fuel line it is only bit they share via the injectors
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Try getting a cylinder compression test on engine that should help and see if the pressure drops on 1 cylinder
Aug 6, 2013
12,071
16,836
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
No that could never happen - the pressure needed to open the injectors is well in excess of the combustion pressure. If it wasn't the engine wouldn't ever work. There is no way on earth that engine oil can end up in the fuel tank because of any engine fault. Even if it had been poured into the fuel tank it would mix with the Diesel, the engine would continue to run, and the fuel filter would not clog. The only symptom would be a very smoky exhaust and even for that to happen there'd need to be a very large amount of oil mixed with the Diesel.
43,805
53,165
Precisely.....
Cylinder pressure on compression stroke approx 300psi to 330psi
Injector pressure at injection 36000psi
And if it could happen it would only force the tiniest amount of diesel back through the injector, there is no oil in the combustion chamber to speak of to be forced back.
