Totally respect your cleverness
What size pack would supply a 2kw inverter
I'm not sure you can. I know you can tether two EZA's together with a coupling unit. I don't know if you can connect a 2k inverter to the coupling unit.
The BIG problem with the Victron batteries is that they only come with a 2 year guarantee, whereas the Varta’s come with 4 years@Robert Clark
As I'd hazard a guess you'd possibly look at the Victron LifePO4's if you did go down this route, I had a look at the specs.
A 2000w inverter will draw 160A at full power (2000w divided by 12.5v for anyone interested).
The Victrom 90Ah can continuously discharge at 270A
The Victrom 160Ah can continuously discharge at 400A
Product confidence wins
Mrs C reckons I’ve spent (invested) enough already.@Robert Clark Your Victron Multiplus is fine for Lithium but you will also need a BMS (battery management system)
If you are on Euro 5 or 6 you will also need the Victron Buck Boost.
Add the above with connecting leads to a Victron 200Ah LifePo4 ........£3,385.00
Expensive but its a good setup. At least with the Victron Lithiums you can pull some big Amps from them. From memory I think its around 300 Ah.
Something to think about
Agreed. The batteries I'm looking at (300Ah smart LifePO4 setup with Bluetooth etc) come in at around £1600 (from memory - loads of figures in my head today). A 5 year warranty can be added for around £100.
Thing is, I'll be ordering from abroad (Europe), so not sure how good that warranty would be. Think I'm going to take advice I've had from @Gromett and be clinical with how they are charged and min/max voltages (system I'm looking at has fully programmable BMS)
Thank you !Just in case you change your mind @Robert Clark
Highly recommend these guys....https://store.meadotech.com
They even reply to emails late in the evening
Basic physics down to 22% that means he had to get 101 a/h back into the batteries in 20 mins, they may charge quicker but you have still got to replace 101 a/h where are you going to get that from with a standard alternator, to do it in the 20 min he claimed you would have to be charging at over 300 amps and that is not allowing for any losses in the charging circuit or cables.Hi Lenny, Can you say on what you base your opinion, I mean do you think he is mistaken,( I am sure he is not intentionally lying). I am just trying to get to the advantages and if he is wrong I would like to know why he is wrong, Its always nice to make an informed choice and I am looking for as much evidence based information as I can get.
If length of guarantee is a factor the Relion (US make) sold by Alpha (UK) come with a ten year guarantee.The BIG problem with the Victron batteries is that they only come with a 2 year guarantee, whereas the Varta’s come with 4 years
The battery project is currently on the back burner. But prices have fallen so much over the last 12 months I will be buying new.
https://www.ev-power.eu/Winston-40Ah-200Ah/
for instance 4 x 160Ah Winstons will be around the £600 mark. My existing Sterling charger will work with it, and I will be looking to upgrade to a Victron MPPT controller which also handles my requirements.
i will be creating my own simple BMS as I will be bottom balancing my batteries to prolong the lifespan.
Project is on the back burner at the moment as I have higher priority drains on my budget, However hoping to have this all in for next summer.
The way I see things, if multi billion companies such as Boeing who spent literally hundreds of millions in developing the Dreamliner can't get it right with lithium based batteries, https://www.scientificamerican.com/article/how-lithium-ion-batteries-grounded-the-dreamliner/, developed by one of the world leaders in battery technology (Yuasa), then I am damned if I would be prepared to trust my life or that of my family to the promises of a UK limited company (RoadPro)`whose recorded capitalisation is £1,000 and whose balance sheet wouldn't buy a modest motorhome (£86k positive in 2015 https://beta.companieshouse.gov.uk/company/01587959).
It's a rhetorical question, but I will ask it, whose record for investment in safety and design excellence are you likely to place greater trust in?
Technology is changing battery design very rapidly, it would appear that LiFePO4 technology - whose reputation for safety appears to remain under scrutiny - is likely to be supplanted very soon with the advent of lithium or sodium glass electrolytes (http://pubs.rsc.org/en/Content/ArticleLanding/2017/EE/C6EE02888H#!divAbstract) for mass storage, as described here: https://www.forbes.com/sites/jamesc...echnologies-keep-getting-better/#5fa5e6be4e62
There is an argument for just seizing the moment and buying a new technology in the knowledge that it has a limited span before it becomes inevitably redundant, companies such as Apple and Tesla are certainly exploiting that limited market to the full. But as sure as the once fashionable iPhone 6 in your pocket will end up where it belongs in the bin before too much longer, the battery technology of today is destined to become hopelessly obsolete within the next 5 years. Depreciation of 600 spondoolicks a year is a lot of moolah to pay for the privilege of being an early adopter. Heck, it even makes an iPhone X look like a bargain.
As I said before, if people want to buy into what is available today in the knowledge that there is better at lower cost around the corner, then good luck to them.
Seems we are on the same page Gromett
I still have to read up on bottom balancing, but how difficult would it be to create a bottom balancing BMS that monitored real time battery status and charging current?
Maybe something Arduino based with a simple LED display?
Thanks for the info, I really like the speed of recharge and to me that is worth something, but there seems to be some conflicting views as to whether the claims for recharge are possible.Correct, he said he was down to 22%. He started the engine to make sure all was ok to start. Then charged it to 100% with a "20 odd mile" drive. I'll try it when I get the opportunity - soon I hope
I haven't looked into it too much just yet due to other projects on the go at the moment. However off the top of my head, 4 inputs to monitor the voltage of each cell.
2 relays. One to cut off the charger if any cell went over voltage. The second to cut the battery bank off if it went under voltage. However it would also include warning methods to warn you when you were getting close to cut off voltage so you could reduce usage. At some future point in time I would probably like to add a shunt and create a simple coulomb counter as these are much more accurate on LiFePO4 batteries than on lead acid as Peukerts is not so much of an issue.
Anybody want to buy an iPhone 6?The way I see things, if multi billion companies such as Boeing who spent literally hundreds of millions in developing the Dreamliner can't get it right with lithium based batteries, https://www.scientificamerican.com/article/how-lithium-ion-batteries-grounded-the-dreamliner/, developed by one of the world leaders in battery technology (Yuasa), then I am damned if I would be prepared to trust my life or that of my family to the promises of a UK limited company (RoadPro)`whose recorded capitalisation is £1,000 and whose balance sheet wouldn't buy a modest motorhome (£86k positive in 2015 https://beta.companieshouse.gov.uk/company/01587959).
Is this about sex toys?I still have to read up on bottom balancing, but how difficult would it be to create a bottom balancing BMS that monitored real time battery status and charging current?
I’m not sure what the EZA electronics do in terms of stabilising the voltage presented to the rest of the vehicle. I think that the natural voltage of (four cells of) LiFePO4 is 12.8V which is close to a fully charged Lead Acid battery. What can harm some 12V devices, though, is the voltage applied during charging. If EZA shields the habitation circuit from high (or very low) voltages, it may be that the use of such a system could prolong the lives of the equipment using it.
