- Nov 22, 2018
- 1,796
- 15,159
- Rimor Europeo 87
- Five years plus three tugging
Morning.
We have one 11kg Gaslow refillable & one 6 kg Calor on dual pigtails. I do most of the cooking outside on a Broken Link Removed and Weber Q1000 (which doubles up as an oven), both of which have got hose adapters.
Currently, what I do is connect the BBQ to the Motorhome gas outlet, and the stove gets connected to the Calor cylinder, which I take out of the gas bottle compartment.
What I want to do is connect both to the motorhome external gas outlet, BUT be able to detach either one, and use the other separately.
Am I right in assuming that I need a Y shape connector, two in-line valves and two quick release fittings?
Or am I better using one Y shape adapter with separate valves and two quick release fittings?
Or is there a better way, that someone has used?
Thanks very much!
Thanks very much!
