engine turning but not firing (1 Viewer)
swiftcalled1ggy
sw scoland
fiat ducato swift 1.9td
newbie
Hi folks,can anyone offer any advice? I started my Swift Ducato 570 1.9td after a couple of weeks sitting idle on the drive,anyway, it started fine and i moved it a few feet letting it tick over, i noticed the fuel gauge had not moved,after a few more minutes i switched the ignition off. When i went to re-start ( 5 minuts later)the engine ,after the heater plug light went out it would only turn over but not fire up:cry:I knew there was fuel in it but put 5 gallon in just incase someone nicked the fuel but this didn't solve the problem,anyone got any advice cos I'm at my wit's end :Doh:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Could be that the fuel cut off solenoid has now stuck in the off postion, try turning the ignition on and off a few times.
Peter
43,332
49,527
if some scroat did syphon it dry you may need to bleed the system.
i think the 1.9 has a mechanical pump so if the fuel filter housing has a button on top press the button until it cant be pressed any more.
try starting....
if it still wont you may need to bleed the injectors.
do this by 'cracking' (loosen) the injector feed pipes, one at a time, while cranking until fuel appears then tighten.
otherwise it could be the fuel cutoff seloniod or fuse is faulty.
haganap
12,760
26,462
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
what age is your van? does it have a factory fitted immobiliser? they can be a bummer for not deactivating, are any lights still on the dash?
rule this out first as it's a common problem.
IF they never blow why do they have them :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
I didn't say they never blow, I said they should never blow. They blow only under a fault condition mainly to prevent a fire when the cable gets hot.
The fuse is usually chosen to suit the cable size though it can be lower if a convenient cable size is capable of a lot more current than the gadget requires. So a 10A cigarette lighter socket could be wired in 20A cable but the socket would melt above 10A and therefore a 10A fuse will be used.
If you don't find the fault it remains there just waiting to happen again.
Hayleylulu
Banned
Feb 17, 2008
5,326
3,827
Full timing in the van
Fiat decato
8years
well thats me been told:roflmto:
