Let me try and explain what I want to do.
I want to power my reversing camera and reversing sensors from the hab battery via a switch on the dash powered from the cab battery which is also used to trigger the head unit to look at the camera video feed.
I read that both sides of the relay are isolated so the power from the dash switch to energise the coil in the relay is totally seperate from the power switching of the load (camera & r/s)???
How much power (how many amps) does it take to energise the coil in the relay ???
Since the hab and cab batteries have a common "earth" -12v it makes no difference where the negative connection is made ???
Would it be better to use a solid state relay (less trigger amps) ???
Suggestions for a SS Relay that is DC switching and DC load ???
Thanks in anticipation.
Bern
Bern
