haganap
- Dec 5, 2007
- 12,949
- 27,769
- Niesman+Bischoff 79e
- I'm an oldbie MH number 10
Ok, so a couple of issues as I start to repair jobs on my Hymer.
Starline 690 on a Merc.
Number 1)
The heating works fine on Gas but is not working at all on Electric. It's an Alde 3010 system I can see nothing on the panel that indicates the electric is plugged in, it allows me to go up to 3kw on the panel. So just before I get my hands dirty or book it in to Alde in Northants , I want to check the obvious.
Electric plugged in - yes
Fuses on the distribution board (when I can find it)
Fuses in the electro block
Fuses on top of the boiler (two slow blow fuses from memory)
Anything else obvious people can think of or offer an explanation as to why if all above is checked it is not working.
Number 2)
Fridge - Initially the issue with the fridge was it appeared to not turn off? (Dometic 8505) However, I can now turn it off but it will not work on (you guessed it) Electric.. Works fine on gas and cab battery when driving. goes nice and cold but when electric is plugged in the Auto goes to gas and when you manually select Electric it bleeps and does it's thing.
Electric Plugged in - yes
So again check distribution board fuse
Check Electro block fuses
Checked the plugs in the back of the fridge, all nicely secure.
Anything else people can think of before I press order on the new PCB board(s) choice of two. or any testing that can be done.
TIA.
Number 1)
Number 2)
TIA.
