That is not a voltage stabiliser, it is a protection device.I fitted a Sollatek AVS30 following recommendations on here.
its basically a step-up transformer you require
Well it kept our fridge going when needed. The alternative - moroccan gas did tend to soot up the burner and flue.That will give a fixed ratio between input and output and won’t actually control within limits (i.e. the output voltage will vary in direct proportion to the input voltage) so won’t really provide what is required.
Ian
It reduces the amps to improve the volts. A lot of frenchies use them.That will give a fixed ratio between input and output and won’t actually control within limits (i.e. the output voltage will vary in direct proportion to the input voltage) so won’t really provide what is required.
Ian
As said it's mainly for fridge use..keeps it running.
Voltage regulator.Voltage stabilisers, or transformers?
I must be forgetting how transformers work.
Ian
Voltage regulator.![]()
I think my mis use of the correct adjective is really immaterial. Lots of motor-homers were using them on the three occasions we've been over there.
The Moroccan grid system is fragmented, voltage levels fluctuate due to long transmission lines, and extreme weather changes.
