- Feb 24, 2013
- 13,083
- 101,452
- Hymer S800
- not long enough
I had a potential problem with a rear wheel 'wobble' slightly concerned that it might be a loose wheel nut following service last month, a mechanic friend came up with tools to check the wheel nuts, all good
He then suggested rotating the wheels on the axle, which meant removing them, but he hadn't brought a jack, we don't carry one, but I told him I could lift the back to get the wheels off with my levelling jacks
Well I thought I could, deployed jacks, full stretch, not off ground , had to put blocks under pads to raise their height, then it worked, but only just
made a mental note to put in some wooden blocks in case we needed to do the same at the roadside
then rethought and decided that didn't seem right, so let jacks up, removed blocks, lifted one side only, now well clear of the ground
well at least as clear as it was with the blocks under lifting rear only
So I don't need to carry wooden blocks after all
But I couldn't achieve the same as other E + P owners and lift the all the MH wheels off the ground in one go
everydays a school day
