Ducato Windscreen Scuttle Drain Holes (2 Viewers)
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
I agree about the gutter. It’s probably overkill.
They are available in Red White and Blue as specials. 😉
Oct 9, 2019
4,959
17,300
Todmorden
Van conversion
FUNSTER in a PVC
Do I need these for my Citroen Relay 2018 model ?
TwinGt
Fiat Adria twin Gt
This will be the final kit complete with hoses.
The items you will need to fit it all is as follows
4mm, 12mm, 15mm. drills
6mm Allen Key
Black Sikaflex/Silicone.
Items that need removing are the panels above the headlights. Headlight removal is optional, but makes the job much easier if they are out. Should be around £25 including p&p. Will you guys let me know if you would use the gutter as it’s not really needed, just thought it might be good idea. 👍. Should have it in the classifieds in a day or so.
Cheers Paul and Chrissy.
Where can I buy this kit please
Two on Tour
10,325
50,963
Elddis Autoquest 175
PaulandChrissy
Fitted the kit to our van and it works a treat. (y)
Nov 29, 2018
25
68
Stevenage
Adria Twin PVC
4 years in
Put me down for a kit! Having spent nearly 4 grand last year on new engine rebuild, after the glow plugs were rusted in. A bit of after the horse has bolted but may stop from happening again.
Cheers Martin
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Cheers Martin
Hi Smarty Marty
sending you a PM. 👍
Jul 28, 2008
813
731
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
would this fit an x290?
Similar issues with water getting onto fusebox and rusting that, as well as injectors. I've "bodged" something preventative but a decent fix may be welcome.
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
it fits X250 upto the body change in 2014. I was under the impression that the newer models didn’t have issues. My brother has a 2016 body and I haven’t seen any problems with his. Have you got any pictures of where it leaks.
Jul 28, 2008
813
731
Wiltshire, UK
Ducato Sportivo
Its the corners from the windscreen, it sort of goes into the corner (NS & OS) but then most of the water goes under/over existing rubber over the fusebox - some have mentioned issues there.
I just used sealant around various bits so most water goes where it is supposed to.
For sure, I check the drain holes run free!
Nov 18, 2016
735
1,117
Worcestershire
Burstner Elegance
Well this may be the answer for my Burstner Elegance! I have the X250 chassis but my windscreen area is different. It’s high on both the sides but a lower section in the middle. This is where the water sits.
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Have you got a picture
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
Very interested look forward to the final products
Nov 18, 2016
735
1,117
Worcestershire
Burstner Elegance
Righty ho, let’s see if these work! :giggle:
PaulandChrissy
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Hi ASR
I can make some to fit that. Do you just need drainage pipes in the central area where it drops down. Do you have any problems on the sides.
Cheers PaulandChrissy
