It's not visible as it has been removed to take off the head, which is the bit in the right hand photo. It looks like a piston has whacked the valves. Cause probably as suggested the cam belt has slipped.Which bit in the photos is the cambelt?
Bloomin' 'eck, what a mess!UPDATE
Cambelt IS intact.
Not in the pic. It has to be removed to take the head off.Which bit in the photos is the cambelt?
If it was mine I'd want a new engine. The cylinder bore will be scored and at the very least it'll need a rebore, new cyl head, set of pistons, valves and there'll be metal swarf throughout.....................
Wow that is similar.Picture attached of similar damage to a 2014 engine that occurred to a lady living in Germany, that occasion cost her just short of 14k.
That particular one was not associated to the cam belt, the German Fiat garage that carried out the work suggested the valves failed!
its not a given that the bore is scored weve rebuilt one new piston and new head ,valves embed in the soft ally of the piston and stay thereBloomin' 'eck, what a mess!
Like this.........its not a given that the bore is scored weve rebuilt one new piston and new head ,valves embed in the soft ally of the piston and stay there
The belt tension could've been too little when fitted or an intermediate pulley could've failed and the belt skipped a tooth or two.Not an expert by any measure but if the Cam Belt was fine when removed and changed a few thousand K's ago what chance has this poor man being successful with a claim against the garage that changed the Cam Belt ? Could there be another cause that results in the same failure mode ???
Thanks Mixyblob for the feedback and pictures.
Wow that will be difficult to prove..The French garage seem to think the UK garage fitted the new cambelt with the timing slightly out. They think it was probably started before they realised and before they re ajusted the timing correctly.
Concequently some damage had already been done, which explains the valve contact marks on the other pistons.
Looking at the marks on the other pistons I'd agree.The French garage seem to think the UK garage fitted the new cambelt with the timing slightly out. They think it was probably started before they realised and before they re ajusted the timing correctly.
Quite possible.The French garage seem to think the UK garage fitted the new cambelt with the timing slightly out. They think it was probably started before they realised and before they re ajusted the timing correctly.
Who actually changed the belt, was it a Fiat professional garage?Our 2014 Ducato based Globecar Campscout ground to a halt yesterday halfway through our tour of France.
It suddenly lost power, accompanied by some weird noises from the engine and gearbox area along with a dashboard that lit up like a 70s disco.
Attempting to restart it resulted in a "donk" as the starter motor tried to turn unsuccessfully.
The vehicle will roll ok as we found out later when recovered by a low loader.
We are luckily now parked at a private aire, awaiting our breakdown company to deliver us to the nearest Fiat garage in Albi once France wakes up after the weekend.
The van has done 22000 miles and had a full service, MOT and timing belt change just before our trip.
No external signs of damage, no leaks, smells or anything obvious.
We were just wondering if anyone has had a similar experience of if any mechanical experts might have a guess as to whats occured, pending a very expensive bill from Fiat.
Looking at that and if timing belt still intact the engine has at sum time been mis timed causing fatugey on valve stem as no other valves are bent in other cylinder's this suggest to me valve failureUPDATE
Cambelt IS intact.
As per the rules of the forum, I'm not going to name the garage that carried out the work, especially as its not been proved that they were at fault… yetWho actually changed the belt, was it a Fiat professional garage?
I did not ask you to name them just to confirm if it was a Fiat Proefessional garageAs per the rules of the forum, I'm not going to name the garage that carried out the work, especially as its not been proved that they were at fault… yet
Definitely more than whacked them .....It's not visible as it has been removed to take off the head, which is the bit in the right hand photo. It looks like a piston has whacked the valves. Cause probably as suggested the cam belt has slipped.
Certainly won't be refitting that head.If I had it rebuilt as you suggest with just a piston, valves, head skim etc. I'd sell it afterwards.
Exactly. In the unlikely event that it would work it'd be an unacceptable bodge. That's why I'd get shot of it.Certainly won't be refitting that head.
There's very little left of the valve seats and nowhere to fit new seats due to extensive Damage around the valve holes .....far too much damage
Don't know what I would do in your shoes, really sympathize , if I had to foot the bill with no insurance or warranty, I don't think I could afford it, but the thing is what do you do, the van is no good without an engine, but will you ever get it back, if it was me with my van not worth a lot I think I would scrap it and get another, but with a van that's worth a lot you don't have that option, just hope you can get something back one road or another.As per the rules of the forum, I'm not going to name the garage that carried out the work, especially as its not been proved that they were at fault… yet
No, not a Fiat garage.I did not ask you to name them just to confirm if it was a Fiat Proefessional garage
