dual pole leisure batteries (2 Viewers)
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Attached an additional cable to the threaded 2nd pole of leisure battery so both threaded poles are different sizes tried metric nuts but not quite right so bit of searching ends up 1 pole is 5/16 the other is 3/8 bsw.
Cant understand why they are not both same size considering wiring is colour coded.
Anyway managed to get nuts as wingnuts so no spanner needed to undo them or tighten them
19,376
30,366
I think its called the "belt and bracers" approach, and have you seen Hymer's colour coding of power cables:xrofl:
So I guess then that the +ve will have the larger stud.
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Yes + is larger stud
metric threads would of been easy to get BSW threads is finding somewhere local that has them
Dec 12, 2010
5,415
21,601
Cumbria
Even the most up to date digital camera still has a 1/4" BSW tripod bush fitted to it, surprised they hadn't been merticfied years ago, didn't know that about the battery terminals though.
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
All pipe threads are still imperial bsp sizes even in Europe
Yep I know about the pipe fitting - only the yanks use some strange thread for their pipes.
I have come across another surprising thread size recently, but blessed if I can remember what it was.
11,956
16,570
Hymers use of colours for what are DC supply cables is completely logical. I don't know why anyone would think they should match the colours used for AC?
Two on Tour
10,335
51,081
Elddis Autoquest 175
What make of battery still uses BSW?
Our leisure batteries are twin terminal and the threaded stud is their either BSW or UNC as the threads for that diameter are the same tpi and thread angles are very similar. I also have a twin terminal battery that came of a classic yank tank that was imported and the thread is the same as our leisure batteries as I use the nuts of the yank one for one of our batteries so I suspect that the thread might be UNC.
Two on Tour
10,335
51,081
Are they Trojan?
Not quite with you on that one ?
This is our battery terminals.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Brown and blue are AC colours and have been for many years
For Hymer to use those for DC is confusing
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
My battery is ( multicell sfl ) but terminals must connect within the case as no visible joiner between terminals
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
My Swift has a brown/blue wire from the positive terminal of the leisure battery, and orange/ white from the neg for the 12v supply.
As far as I can remember, my Autosleeper was the same.
jonandshell
5,476
8,299
Not got one!
Schnaudt do the brown negative thing.
Sargent do the too thin white negative thing.
CBE do it better and cheaper. Never thought I would say that about Italian electrics!
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Let me know what you need and i will put some nice S/Steel ones in the post
Andy
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Andy
Thanks for offer went to fixings place they had them with butterfly tops so easy to unscrew without tools got them with some nuts aswell so im sorted ÂŁ2 for nuts and the butterfly nuts as well
11,956
16,570
Agreed for blue - but brown is used as 0v on a number of cars. It's only confusing if assumptions are being made. No-one would find a brown wire on a car & wonder if it was AC Live, or a blue wire and think it might be AC Neutral. Every mains cable in the Hymer, without exception, is a three wire flex that includes a green/yellow earth.
