Drop down bed mattress (1 Viewer)
Jan 31, 2016
1,902
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
Has anyone changed their mattress ?
We are thinking of replacing with memory foam, but not sure if it will be heavier than the part foam part sprung original mattress ?
Nov 4, 2011
5,939
38,917
Uk
We changed our drop down bed mattress for a foam/memory foam type which is about 3 inches thicker and does weigh more, don't know how much heavier but I will be locking for updated bed struts.
We bought a normal domestic double and cut it to shape with an electric carving knife and also chamfered the front edge to give clearance against roof when it's up.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I managed to squeeze an inch of memory foam inside the original mattress cover and on top of the existing mattress.
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
I never realised you could do that ! did it work out ok ?
Were there no mattresses available of similar thickness to original ?
We did exactly that for our french bed. Perfect . Used the original mattress as a pattern . So much cheaper and fits perfectly .
Nov 4, 2011
5,939
38,917
Uk
We went for the thicker mattress think that being just foam, we may feel the slats of the bed base.
With chamfering the front edge the bed now goes up further than it did.
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
What thickness mattress did you get, and where from ? Mines original & 5" thick
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
Can you close a drop-down bed with a duvet left on it?
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
I see Lidl are selling German made 7 zone foam mattress 150 x 200 for £80 with zip off cover. Weight apparently 65kg per m3.
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
If it is any help we bought one of the zip cover ones ( easy to open and cut the foam and just folded under the excess cover after ) We bought from Ikea after trying each for comfort !
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
Okay I weighed the Hymer mattress, bearing in mind its bits of foam stuck together around a sprung interior, it weighs approx 13kg.
So need to think about this as not sure about the struts limits.
Feb 29, 2012
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
I've just seen these in my local Lidl. They look really good. been thinking of replacing mine with something similar. Has anyone actually bought & used one ?
Would be interested to hear.
Don't have my van handy to measure but thought it was basically double bed size. Could anyone advise please ?
Incidentally we bought a memory foam for home use but find it SO / TOO hot at night. So be aware that it's a characteristic of memory foam.
Barrie
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
Barrie
I put a link to that about 4 posts back, that's the one we were looking at. They are varying sizes, about 50mm to long for our 544 but easy trimmed.
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
Update. We bought king size mattress from Lidl. Cost £79.
I was wrong 're weight , it actually referred to weight of people on it.
The king size fits snugly on drop down bed in our 2012 B544. We're off tomorrow for weekend to Cairngorm area so will report what it's like to sleep on. The bed closes up okay so weight of mattress not a problem.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Swapping pressurised struts is not as easy as you may think. It may be better just to assist the old ones a little bit more when you lift the bed.
cliffanger
4,837
34,012
Saltford
Hymer A class
Since 2013
Mine does,,, pillows, ladder, few bits and pieces, it’s good storage for flat stuff!! Spare duvet, pillows,,
But my mattress is only 4 or 5 ins thick!!
We do too. We use an Abru 3 step up instead of the original stepladder, so it’s much bigger and it sits on top of the duvet, and the silver screen is there too. Everything fits easily. We have the original memory foam mattress. (y)
Feb 29, 2012
361
225
Hymer 584
Just as an update, I bought the Lidl mattress & have cut to size using a bread knife.
Although the mattress is about 2 inches thicker it fits into the original Hymer cover easily.
Just have to find a night to test it properly.
Off to Bonterra next week so will get a good test there.
BusyBuilder
Jan 31, 2016
1,902
3,377
Hymer B544 (2012)
newbie
Just been out in our B544 and Lidl mattress was fine. Better than original Hymer sring/foam mattress.
We didn't cut ours down although it is slightly bigger than original it's a snug fit on bed base. Lifts up and down fine weight not an issue, if anything it may be lighter than original.
