We re now considering fitting out our latest Mh and thinking about adding a fresh water tap so we can use the tank water for tea etc. Any suggestions for best system?
Jon
Jon
What's wrong with making tea from the regular tap?
I may state the obvious but you will need to consider filtration, if you are using water from the fresh water tank unless you are sure you are not having standing water in the tank.
people talk about filtering down to microns to keep the bugs at bay.
Would never drink from mh holding tanks.
Even thou cleaned water can get left behind and go stale
Just the thought of it is enough. Always carry small water container for fresh water consumption, even to put it in kettle to boil
Even though we can carry 170 L we still carry 5 L bottles of water just for drinking, Coffee/tea. Refilled the bottle from a CAMC site the other week and it smelt really chlorinated. When in Europe, although some here will swear they use the local tap water, we buy bottles - as do most of the Europeans we come across. Be interested in following this post as a solution should be good.Would never drink from mh holding tanks.
I fitted a Franke filter in the cold water line to the kitchen sink as we had one at home and the filters last forever. Like you Jon we prefer nice tea! We used a Brita jug for some time until this. Unfortunatly the Franke is more of a mains pressure carbon filter so the flow and pressure at the sink is lower by a noticable margin, but it does not cause any issues. I like the way it dismantles. Here nearing completion of fit.
We carry a 5 litre container for water for tea and coffee making,,BUSBY.We re now considering fitting out our latest Mh and thinking about adding a fresh water tap so we can use the tank water for tea etc. Any suggestions for best system?
Jon
Always use potable water from taps on sites when in Europe,,always makes a decent brew,,,BUSBY.Even though we can carry 170 L we still carry 5 L bottles of water just for drinking, Coffee/tea. Refilled the bottle from a CAMC site the other week and it smelt really chlorinated. When in Europe, although some here will swear they use the local tap water, we buy bottles - as do most of the Europeans we come across. Be interested in following this post as a solution should be good.
Same here - and received a number of free cartridges direct from General Ecology in the US as compensation for what happened. No need to avoid but definitely ensure you get the right cartridges.I have used Nature Pure for over 10 years and never had a problem but I do only use the correct filters, as Jim said there was some dodgy ones about.
Available online Jon, search Franke Undersink Filter or some such. I am down the van until after lunch, but if you cannot find them I can post a link this afternoon.I fitted a Franke filter in the cold water line to the kitchen sink as we had one at home and the filters last forever. Like you Jon we prefer nice tea! We used a Brita jug for some time until this. Unfortunatly the Franke is more of a mains pressure carbon filter so the flow and pressure at the sink is lower by a noticable margin, but it does not cause any issues. I like the way it dismantles. Here nearing completion of fit.
It used to be an easy choice and we would recommend the General Ecology "Nature Pure" However we ( Techno actually ) caught their UK representative scamming the public re-badging cheap taste filters, and selling them as expensive bacteria and virus filters. That the British scammer still supplies their products in the UK tells you all you need to know about them. AVOID
In the home we use a Big Berkey it's simply the best water filter going and filters last for years We use the flouride filters with it and the taste of the water is amazing. We do take it away with us, However in the RV we have the workspace. When we downsize we will need something fitted, or because we are so impressed with it we may go for a Travel Berkey and find space for it. I know a couple of full timers who use a Travel Berkey. It means you can source your water from anywhere and once through the Berkey it's bacteria and virus free and the taste is just so pure.
JJ do you have the Travel Berkey?
I think Ive found it thanks Michael. is this it?Available online Jon, search Franke Undersink Filter or some such. I am down the van until after lunch, but if you cannot find them I can post a link this afternoon.
Seems like a good solution except as posted here a concern about the pressure needed - not that it’s the time but the thought of messing up the Motorhome pump which is critical for everything else. Also our filter cassette at home does get inefficient after about 4 months, you may need to replace the filter every time you go away as it will hold whatever it is it filters!
