Dorema Highlander Awning - Plastic Fitting? (1 Viewer)
zen navigator
111
Manchester
Coach Built
Hi,
Pretty much a newbie and enjoying my a first summer in the Motorhome.
My van is a Fiat Ducato Autoquest 400 1990 model. It has a mechnical awing fitted. The awing was pretty dated and seen better days, although the wind out capony is fine and dandy.
Anyway thought I get one of those Dorema Highlander awings for long stays. As it seem the best general fitting awning for a Motorhome.
The Dorema website says...The attachment of the tunnel to the side of the motorhome is by means of an easy fit plastic fitting that clips onto the rain gutter of the van.
But the manual says nowt about it and it didnt come plastic fitting. So what is this Plastic fittings.
Anyone got one who can point me in the right direction?
Dave
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
I would suggest you go back to your supplier and ask them, it could possibly be a J rail but they do not clip into the gutter.
Regards
Peter
J and M on Mfun
75
11
Lincolnshire, UK
Motorhome
hi, i think you may be describing a figure of eight attachment, its a plastic strip that slides onto the awning rail, then you slide the awning side into it as well, looks like this from the end )( search on ebay, or google image, hope that helps xjx
As can be seen from following piccy it can clip straight to the gutter
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Figure of 8 and the J rail can be found on our website or give us a ring during the day and order over the phone, mention Motorhome Fun for your 5% discount
Peter
Z
zen navigator
111
Manchester
Coach Built
Hi,
You were spot on there. Thats exactly what I wanted and have now found where I can get them from.
Dave
43,332
49,496
got to be careful here as there are two sizes as i found out.
the joining tape may have two beads of the same size (8mm) and wont fit in the awning groove.
you need the one with two different size beads..about 8mm for the one in the figure 8 and the other is about 6mm to fit the groove.
the bottom pic is wrong.....it may well clip in to the rail but anything more than a stiff breeze and it'll pull off...i know...i tried it.:Angry:
cant understand why they havent made a modified figure 8.....
one side to have a solid 6mm 'bead' and the other to have an 8mm 'C' tube
instead of two C tubes.
that way you wont need the fabric joining tape:thumb:
