Dometic hob ignition (3 Viewers)
Bobby22
1,537
6,408
Rapido 680ff
since 2013
I have a problem with my Dometic hob ignition........i've lost my spark.
When i press the switch i get no spark. Over the last few months i have been getting an intermittent spark but now it has stopped altogether.
It seems that it doesn't work from the 12v hab system as when i was getting patchy sparking i switched off the 12v main switch and still got some sparks.
I have read the manual for the hob but there is no mention of the igniter in it.
I have looked for seperate batteries for it but can't find any.
My van is a 2016 Rapido 680ff............any thoughts?
Nov 2, 2014
332
295
Maldon Essex
could be the switch I replaced ours last year.
Ours has a small rocker switch price from Dometic was about £20 + P&P
Ebay £1.50 delivered
andy63
4,672
15,018
south shields
since 1990
hi bobby, can't really help, but id be surprised if it didn't come off the 12v system if there is no mention of batteries in the instructions..
lost the spark on my oven and pulled it out to have a look... never did find anything obvious ,but suspected the push in switch... anyway it started working again :D2...
hope all is well..
andy
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Re switch, i have tried bridging the wires at the terminals with no luck.....how else could i test the switch?
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
I think the hob will still be under warranty. I would contact Dometic. I don't have my manual to hand but I think they come with a 2 year warranty.
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
hope all is well..
andy
Andy , it seems my fridge also works ie lighting and ignition independent of the hab main switch.
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Its less than 1 year old, i'll get it attended to when i'm at the dealers for service.
My only problem is when i take it back and it needs a part it could be a double journey.
andy63
4,672
15,018
south shields
since 1990
You could check the voltage at the switch... if thats OK then you would need to find the unit it supplies by tracing the wire from the switch.. that unit will supply the hob electrodes...
If all those connections can be checked and the electrode insulators art broken there's not much else left other than the spark generator...
Worth a look if you can get access. ..
Andy
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
The wires are not easy to get at apart from the switch, i reckon by bridging the wires i blew a fuse 3amp that turned the electronics off on my fridge. I have replaced the fuse and checked the others. I'm reluctant to mess around with it as its under warranty and i will be going back to the dealer soon. A good old clipper will do for the next fortnight.
I thought i would air it in case it was something silly, thanks for your help lads(y)
Must report it in the morning
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
A guess from me. Myra has got it wet when cleaning the cooker so it won't work again til it's dry :D2
I would agree with Andy and get it back into dealers , barely a year old and I certainly wouldn't pay for a new switch.
Nov 2, 2014
332
295
Maldon Essex
I think it was damp from cleaning which killed our switch.
XRN
Oct 10, 2014
312
294
Plymouth
Hymer B680 Starline
We are no longer Newbie's.
Get one of these from the pound shop, my oven ignitor doesn't work and will cost £000's in labour just to investigate so I use this, but under warranty you should get it fixed by the dealer.
Apr 27, 2016
6,875
8,001
Manchester
A class Hymer
Since the 80s
The Hab main switch does not completely isolate the 12V leisure battery. There should be an isolator next to the battery to do that job. The hab main switch turns off most of the hab functions, but leaves things like the electric step, frost protection valve and fridge control connected. I presume the hob spark supply is included in this.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
My hob igniter is not on perm live.. and stops working if control panel is off...
Edit: Thought I'd check oven... that IS on perm live circuit... I was expecting it to be same as hob!...
Feb 22, 2016
3,620
10,747
York
Bailey 620 Approach
Depending on the model of your Dometic hob, the battery for the igniter is in the switch itself.
We had the same issue of sporadic spark/no spark. Manual talked about changing the battery by turning the switch clockwise after pushing in. Didn't work. Then found I was pushing too hard and the turn is anti clock wise. So try GENTLY pushing igniter in (and I mean about 1mm) at the same time turning it anti clockwise. Switch popped out and replaced the worn out AA battery. Now sparks and lights first time.
Hope this helps.
EDIT: oops, noticed it was your hob not fridge. Sorry. Senility creeping up on me!
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
I reckon it IS the switch, no continuity on multimeter,
Strange thing is when i try to by pass the switch the fuse blows........or it could be shorting on the stainless steel.
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
99p delivered from ebay.
Mine was done under warranty.
Bobby22
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Take the valve out all together......sorted. But make sure you are safe in the colder weather.
138go
3,276
14,613
Carthago 138
Since 2001
Switch for Dometic Hob ..
Terminals are the same and size is spot on only difference is it has a dot on the top
