Fridge worked this morning on gas. We loaded up and headed off to Lyndon Top.
Now the fridge is dead. The front panel is dead, I can't get anything to happen when pressing the buttons. Gas is on, water is hot and pump works. Fridge won't work on engine either.
All other gas and electric systems work, there is no EHU here. All fuses seem ok on the PSU and the external"EB" board.
I've poked around and can find 12v off the big white plug all the way into the module at the rear.
Also noted a small kink in the ribbon cable on the outermost cable, I'm guessing that this is the front panel cable? Seems ok but ill have a closer look later.
I've read a few posts but nothing seems to match my issue, not that has a happy ending anyway.
I've not yet looked at battery, or cab or engine fuses or relays as I'm not sure what to look at really.
I'm looking for a bit more help then please. Any wiring diagrams? Guidance on what things to look at?
Usually undaunted by these things but I'm stumped now
Thank you...
Thank you...
