Dometic 7655L fridge not working on gas (1 Viewer)
955matt
208
130
bexhill on sea
Hi, found our fridge not to be cooling on gas , freezer works fine just the fridge.
1/ Removed the burner and cleaned out the flue
2/ Hovered the burner assembly out
3/ Swapped gas bottles to a full bottle
4/ Turned the temp setting right down and left running for 4 hours than slowly turned it up
5/ flame looks good and strong and blue and the van is level
6/ hob and heating working fine
Still the fridge doesn't get cold / double checked it on hook up all fine.
As usual we are away to Germany with no hook up next month and no one can look at it before we go.
Any ideas as I'm running out, last thing to try is a new jet and burner
Aug 20, 2007
574
637
Leyland
Frankia I7300 BD
since 1997 (many years tugger before then)
I always remove the jet and check the tiny hole out using a magnifying glass, the tiniest trace of muck will affect the efficiency / cooling of the fridge.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Did you clean the flue out? Badly burning fridges cause soot which sticks to the inside face of the flue and builds up to create an insulating layer stopping the heat of the flame being absorbed into the cooling circuit. As it works fine on electric the cooling circuit must be good so it has to be something stopping the heat being absorbed. Remove the burner assembly and clean the flue with a narrow bottle brush.
D.
Feb 24, 2013
13,083
101,456
Bolsover, Derbyshire
Hymer S800
not long enough
I do cringe when I read about unqualified people 'fixing' gas appliances, maybe if already away somewhere I might just look to improve or temporarily fix something, but then get it checked by someone who knows what they are doing as soon as back
Do the same people service their own home gas boilers? o_O
We get ours done as part of the habitation service. having said that good service centres seem to be booked up for months ahead, so needs to be planned in
Each to their own I guess :)
Armytwowheels
6,475
14,879
Market Harborough
Carthago S Plus - Iveco
Since 2011
But Dave, it's a bit different to self servicing the exhaust bit of the fridge to the gas supply side. If Colin did not service and clean the fridge when we are burning Moroccan or Spanish gas for month after month, our fridge would pack up every few weeks.
Feb 24, 2013
13,083
101,456
Hymer S800
not long enough
That's an interesting point Sandra, I did not realise that gas could be so bad as to cause such a quick service requirement
But the exhaust side is also the bit that will generate CO, I do still think some do not seem to take it seriously enough
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
"We get ours done as part of the habitation service." I presume you specifically ask for the fridge to be serviced then as very few workshops do it as a standard part of a hab inspection. I do service the fridge on a hab insp if it can be done in situ (many can't).
D.
Feb 24, 2013
13,083
101,456
Hymer S800
not long enough
D.
I do indeed, must be about the only well designed thing on my MH, the fridge workings can be fully accessed from the outside, or so I am told o_O
955matt
955matt
208
130
bexhill on sea
Hi Dave yes clean the flue, not very dirty .
We have only had the van a couple of months and no one can look at the fridge before we go away otherwise I wouldn't touch it.
I would have thought it could only be gas supply or the burner as every thing works on hook up.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
If it works ok on hookup then the cooling circuit is functioning well, it can only be down to the size of the flame or there is some reason the heat is not being absorbed into the cooling circuit. Did you check the baffle in the top of the flue?
D.
53,449
150,098
Yes and fitted my last two boilers myself, I trust my own work more than so called professionals.
Habitation service to me is a waste of money, nothing I can't do myself. The dealer we have brought our last 2 Hymer's from if you ask him about habitation service he says not necessary for 5 years and they are quite a large Hymer dealer.
955matt
955matt
208
130
bexhill on sea
Baffle is in the top of the flue all ok, I know the van was used mostly in Spain before we bought it so thought the flue would coked up.
I don't have a bottle brush I just used a thick cable with some wire wool on the end which was a tight fit, some soot and rust came out but not much.
The T piece on the top was interesting to get the screw out of.
Armytwowheels
6,475
14,879
Market Harborough
Since 2011
Which is why it is a good thing to learn how to service the exhaust side, then you can be sure you are not breathing in dangerous CO. Or the moment you detect it not burning properly, you can do something about it.
As for the gas being bad, we went through a stage early this year when Colin cleaned the flue every few weeks, then it was not and has not been necessary since, we can only assume this was dodgy GPL. The fact that he knew how to do this and carried the brushes meant it was all stress free and didn't cause any problems. If you are touring for any length of time it is well worth learning how to clean your flue and jet (no pins allowed!).
Of course it's all very well for me to relay all this to you, all I do is sit back with the a G&T and wait for things to be fixed. :ROFLMAO:
955matt
955matt
208
130
bexhill on sea
Double checked the fridge on hook up again, all ok
Removed the burner and this time the nozzle and found the pipe rusty at the end , removed the pipe, cleaned the rust and blew the pipe out.
Still no different :mad::mad::mad::mad:
The only other thing when i cleaned the flue there was a tight spot about 3/4 of the way down , should they be the same width all the way down.
What do you use for cleaning the flue.
