how big a gap between road and brushes is recommended?
so 3mm more than 3/4" or 3.4mm less than an inch for us imperialists.22mm for us.
When did "evidence" get involved in an accessory purchase?Is there any evidence that these provide any tangible benefit?
Ian
They cut down on stones getting thrown up onto front of trailer/etc following , and they cut down on the spray up the back , by collating the atomized moisture into bigger drops that drop to surface rather than get picked up in airstream , they also tend to divert airflow out to sides , and also cuts down therefore on amount that gets sucked up into low pressure area directly behind vehicle . They can be further helped by fitting strakes to rear edge of roof top to divert air into that same low pressure area and further deplete it HTSH .
They definitely do keep dirt off the back of the van and I'm sure off a tow car but never having towed I can't confirm that.That’s the ‘theory’, but in practice ..
I can confirm tactr2mans hypothesis as im often finding myself on the bonnet of towed vehicles if only to check the theoryThat’s the ‘theory’, but in practice .....
Ian
Are you a management consultant Ian?That’s the ‘theory’, but in practice .....
Ian
