Diesel heating (1 Viewer)
Mrs grumpy
5
Autocruice stardream
I'm a newbie
Hi we are new to motorhomes and ours has diesel heating and when we used it at the weekend we noticed that there was water dripping on the outside behind where the heater is not sure if this is normal thanks
Dec 6, 2011
10,989
23,068
South Wales
Coach built Adria
hi welcome , not sure either but could be simple condensate if your sure its water.
Mrs grumpy
Mrs grumpy
5
I'm a newbie
Would this be right behind where the cylinder is in the motorhome
10,989
23,068
South Wales
Coach built Adria
not sure you would need to look up what model etc of heater you got and check its operating procedure
Mrs grumpy
Mrs grumpy
5
I'm a newbie
Thank you will search the books
Mrs grumpy
Mrs grumpy
5
I'm a newbie
Thank you
irnbru
13,472
30,951
Glasgow
Benimar 264
9 yrs
Hi and welcome @Mrs grumpy looks like you've used your free 5 posts incase your wondering why you cant post. Just hit subscribe at the top(y)
SandraL
1,373
985
Somerset
Hymer b694sl
We had a 2005 Starburst with eberspacher wet diesel heating. On the hot water stoage cylinder there was a pressure relief valve with a red knob. As the water heated it expanded and the pressure rekief valve dribbled to keep the pressure down.
The valve could be opened manually to drain the tank in case of frost.
Ours became a bit dribbly all the time and needed a new seal inside.
7,016
18,858
Barnard Castle, UK
Concorde Concerto
Our 2005 Eberspacher did this too, it still worked fine though.
Have you ever had it serviced, ours broke down and the repairer said most people with diesel heating just let them run and don't service or touch them until they break down.
11,850
17,058
derbys
AUTOSLEEPER SYMBOL
At £50 plus vat for a service i don't blame them..I have had mine serviced to keep the 3 year warranty.It was cheaper a couple of years ago to have a new heater £900 than to have it repaired..Friend has just fitted a cheap Chinese heater to his van,,£250. Will see how he goes on with it.BUSBY.
