Diesel heating (1 Viewer)
Mrs grumpy
5
Autocruice stardream
I'm a newbie
Hi we are new to motorhomes and ours has diesel heating and when we used it at the weekend we noticed that there was water dripping on the outside behind where the heater is not sure if this is normal thanks
Mrs grumpy
Mrs grumpy
5
I'm a newbie
Would this be right behind where the cylinder is in the motorhome
11,626
25,545
South Wales
Coach built Adria
not sure you would need to look up what model etc of heater you got and check its operating procedure
Mrs grumpy
Mrs grumpy
5
I'm a newbie
It's a 2007 autocruice stardream
irnbru
13,515
31,144
Glasgow
Benimar 264
11 yrs
Hi and welcome @Mrs grumpy looks like you've used your free 5 posts incase your wondering why you cant post. Just hit subscribe at the top(y)
SandraL
1,373
985
Somerset
Hymer b694sl
We had a 2005 Starburst with eberspacher wet diesel heating. On the hot water stoage cylinder there was a pressure relief valve with a red knob. As the water heated it expanded and the pressure rekief valve dribbled to keep the pressure down.
The valve could be opened manually to drain the tank in case of frost.
Ours became a bit dribbly all the time and needed a new seal inside.
7,246
20,138
Barnard Castle, UK
Concorde Concerto
Our 2005 Eberspacher did this too, it still worked fine though.
Have you ever had it serviced, ours broke down and the repairer said most people with diesel heating just let them run and don't service or touch them until they break down.
12,160
18,029
derbys
AUTOSLEEPER SYMBOL
At £50 plus vat for a service i don't blame them..I have had mine serviced to keep the 3 year warranty.It was cheaper a couple of years ago to have a new heater £900 than to have it repaired..Friend has just fitted a cheap Chinese heater to his van,,£250. Will see how he goes on with it.BUSBY.
