TOAD on Tour
After some advice please
I have a 2015 Sonic A Class, which we’ve owned since January and had no issues at all. I had a solar panel fitted in March with included being able to top the engine battery also when parked. We have the van on our drive and I last drive it approx 3 weeks ago returning from a trip to Devon.
I monitor the battery (leisure & engine) readings from the control panel in the van on a regular basis and the leisure batteries are always around 13.1V and the engine battery used to be around 12.6 - 12.7v but over the last week or so noticed it was 12.3V - 12.4V. So today I thought I’d take it for a run and put key in ignition as normal to lower the E&P Hydraulic Legs and it didn’t have enough power to do so and low battery light came on dash. I managed to hook up on electric and raise the legs that way. When I started the engine, it struggled, but did fire up and noticed 2 linked battery lights in red on the Motorhome control panel lit up, not sure what this was, could the leisure batteries have helped the engine battery to start the engine? Anyway, I gave the van a drive for around 30 mins and parked back up at home with engine off and the van has rested for around 10 minutes and the control panel now says the engine battery is 12.5V (Leisure batteries still reading 13.1V) Do you think the battery is on its way out, or already gone? Any pointers greatly received as I can barely change a light bulb!
