Dashcam hard wiring (2 Viewers)
Oct 23, 2009
784
608
Anglesey North Wales
Adria Twin 640SLB
I’ve just bought a Nextbase 512 dashcam and hard wiring kit . If anyone has already fitted one would appreciate some advice on the best/ easiest routing for the cable in my 2015 9 series.
Thanks in advance
32,656
66,564
9 series ... Rapido????
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Just bought a new NextBase cam from Halfords and asked the guy about a hard wiring kit. He offered to have it fitted for £30. The kit is £20 so fitting is only a tenner......bargain.
Yes, I am having it fitted into the A Class and yes, I will be in the cab while he's doing it and keeping my beady eye on him. For £10 it saves me the hassle of fiddling about in the fuse box while not being able to see what I'm doing.
Richard.
May 31, 2015
11,682
44,529
Ducato PVC
Getting Better
It’s really easy, mines a left handed fiat and I just tucked the cable along the side window surround, down into the dash and straight on the the cab batteries, comes on when I start up and forget about it...
andy63
4,672
15,017
south shields
since 1990
Depends where you are mounting it and what feed you want to power it off... I usually power mine off an engine run signal.. and mount it where the rear view mirror would normally go...
Its Not hard to feed the wires from dash up the pillar trim and tuck in behind the head lining ...
Andy
May 31, 2015
11,682
44,529
Ducato PVC
Getting Better
There’s a few videos on YouTube on how too, it’s surprising what people can do once they start doing it for themselves...(y)
Silver-Fox
9,269
29,110
Cheltenham Spa
Rapido
im a not so newbie
Out of interest did you just chop the cig lighter cable and put an inline fuse in?
Silver-Fox
9,269
29,110
Cheltenham Spa
Rapido
im a not so newbie
No I bought a hard wire kit off fleebay...(y)
Works a treat, got a nextbase 312.. mounted top left of screen..
I’ve been trying to find a mounting kit for my cam so I can mount it on the dash and not have it record upside down :)
Did you just wire yours positive and negative straight to the battery then?
If so isn’t it running all the time?
Just curious :)
Nov 4, 2011
5,941
38,947
Uk
I bought Nextbase hard wire kits from eBay, with them you get a fuse holder that replaces an original fuse, in the hymer I found a fuse that's only live with ignition on and then tucked the cable under the heat duct on the dash and mounted the camera at the bottom of the windscreen.
Easy enough.
43,330
49,446
Believe me, you misunderstood.
They charge £8 to fit wiper blades....A 5 minute job for BOTH blades.
The £30 will be Labour only, the £20 kit on top of that.
May 31, 2015
11,682
44,529
Ducato PVC
Getting Better
Just curious :)
It’s easy to put an inline switch on it, I just turn it off when parked up and it comes on when I turn on ignition, I leave it on when we go into shops in case something happens..
43,330
49,446
It won't be upside down.
The lens doesn't know which way is up and the data sent to the SD card is just that...date, not a picture.
Oct 30, 2010
4,256
20,707
Since 2008
Not so. Definitely told the fitting charge is £30 and they supply the kit in the price.
If it was £30 just to fit I would be doing it myself. But for a tenner it wasn't worth while me faffing about.
Richard.
RogerThat
1,128
991
North West
How or where do you mount a camera if you have cab blinds?
Silver-Fox
9,269
29,110
Cheltenham Spa
Rapido
im a not so newbie
I have a Roadhawk dash cam and it records upside down I tried it :)
I didn’t think it would but there you have it :)
Nov 4, 2011
5,941
38,947
Uk
I mounted mine on a piece of Perspex stuck to the heat duct on my Hymer.
53,440
150,044
The Nextbase unclips actually it just pulls off uses a magnet, leaves the base and wiring in place and if you use the adhesive mount they supply it is much smaller than the suction one (see pic).
I leave mine in place but my screen is about 14" from the blind.
Jul 5, 2013
11,731
13,708
One of the advantages of an A class is that there is room between the windscreen and the blinds, or at least there is in ours. Ours is on the same mount and in about the same position as @Lenny HB shows on his post. The only bit in the swept area of the screen is the bottom 40mm of the camera, which includes the lens. That is as much as you are allowed.
