Bluethunder
I just purchased a damp meter from ALDI works great,tested it against a expensive one and it gave exactly the same reading,only £9.99 really good value.
I just purchased a damp meter from ALDI works great,tested it against a expensive one and it gave exactly the same reading,only £9.99 really good value.![]()
Thanks for the heads upI just purchased a damp meter from ALDI works great,tested it against a expensive one and it gave exactly the same reading,only £9.99 really good value.![]()
i dont know why you think you have to put holes in anything unless the item you want to test is made of tissue paperI'm not keen on putting holes in everything I want to test for dampness, so I'll stick with my Extech pinless moisture meter.
So how are you going to test the moisture content of the substrate that your surface covering is on the if you don't pierce through that covering ?i dont know why you think you have to put holes in anything unless the item you want to test is made of tissue paper
Why would you want to pierce anything unless you think that damp has gone under the surfaceSo how are you going to test the moisture content of the substrate that your surface covering is on the if you don't pierce through that covering ?
I give upWhy would you want to pierce anything unless you think that damp has gone under the surface
so do i ,i dont get the point ( get it), have a good dayI give up![]()
Ah, i am with you now, i was a bit slow on the uptake,(a pensioner thing) i now get what your getting at, i didn't actually see where he pushed his pins to measure underneath,so many thanks to you for helping me outI noted that you were viewing the "Acceptable Damp Readings + Hab Checks" thread where you would have seen the photos of the OP using his pinned moisture meter and pushing the pins through the surface to measure the moisture content below the surface, that's point, get it or maybe you don't.
No problem,i didn't take any offence,keep safe,look forward to travelling many miles and enjoyFrustration got the better of me, so I apologise for my seemingly less the kind approach to explaining my point.
I also have a pinned type moisture meter which are more accurate that the pinless, but I only ever use that to measure the moisture content of the fire wood for our log burner where pinoles don't matter.
On the back of this, walked to local Aldi and bagged myself oneI just purchased a damp meter from ALDI works great,tested it against a expensive one and it gave exactly the same reading,only £9.99 really good value.![]()
Nice one, I'd never though of using our meter to check the firewood, might even buy another one for the house.Frustration got the better of me, so I apologise for my seemingly less the kind approach to explaining my point.
Just got the last one in our local Aldi... what setting do I need for interior walls on the Moho.. 1 or 2 would work I guess?On the back of this, walked to local Aldi and bagged myself one
Thanks![]()
My cheapy Lidl one has pins. Several years old now. Mainly for checking moisture in my flat roof garage and garden shed timber structure.im lost is the alde/lidl one pinless?
I bought an Extech M057 after reading up on various makes and model as it seems to get good reviews and was a sensible price.two on tour....bought a pin damp metre but don't want to penetrate wood. Is the pinless damp metre effective in your (or others) opinion? It's not that much more expensive and i can always use the pin job for the logs! Thanks.
With a pin moisture meter you push the pins through the surface covering and the meter sends an electrical current that flows from pin to pin and measures the electrical resistance.How does any damp meter measure the dampness of material that is behind a waterproof covering? Genuine question.
