Cramer Glass Hob cover fixings (1 Viewer)
steveclecy
880
580
Wirral
Since June 2009
I wonder if any members could assist me in sourcing the fixings for our Cramer Glass Hob cover.
We have a three burner gas hob, and on our first trip, the pan supports were placed in the wrong position, and "someone" closed the lid, putting strain on the fixings, which stripped the thread of one of them. I did try a couple of sites on the internet, the only one who replied told me that I would have to buy the complete lid to get the fixings.
I have tried to upload some pics. The second is of the damaged fixings, the first (v small) is supposed to represent the hob.
Any ideas anyone?
Steve
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
As you have nothing to loose and every thing to gain
Think about a repair
There are many products out there that you could pour into the button, screw in the bolt and allow to set, efectifly re threading the fitting. remove bolt and re fit to lid
Geo
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Try these people Link Removed
They do every type of plastic screw and gizmo you can think of. They also are happy to send you out a few free samples as well, which might get your cooker fixed for nowt!!!:winky: :thumb:
Anyone else should also bookmark this site as they do all kinds of latches, catches, hinges etc etc etc used on motorhomes and caravan all over the world:thumb:
If you cant find exactly the part your after why dont you but a couple of slightly smaller nuts bolts and washers and drill a hole through the plastic broken bit and use it as a spacer to protect the glass??:winky:
steveclecy
steveclecy
880
580
Wirral
Since June 2009
This last suggestion has merit. The "plastic" bit is in fact metal. scratched as I was trying to grip it to get the threaded machine screw to tighten. I have had a negative reply from O'Leary Motorhomes, so as the first reply states, I have nothing to lose and everything to gain. I will look for some material to pour in and set - perhaps an epoxy resin. If that fails, I may drill out and use another fixing through it. The only problem with that is I would prefer something that was smooth or rounded to avoid snagging things on the closed surface.
Thanks to both suggestions
Steve
Feb 18, 2009
574
250
Guisborough North Yorkshi
Malibu T410
Since August 2008
Fixings
Try doing a search for Polymorph Thermoplastic Granules these were once reccomended by Peter from John Cross Motorhomes looks like good stuff maybe he will be along later to put me right if I am wrong
tony morris
315
Calcot Reading Berkshire
bailey caravan
30 months mh 40+ years tugger and camping
Steve
Hi steve have 2 class tops complete that I bought from o'leary m/h brand new never been used both smoked class tops complete with fixing brackets give me a call if interested on 01189413037 Tony
steveclecy
steveclecy
880
580
Wirral
Since June 2009
Thanks for the offer, and I may yet take you up, but that is the frustration, I have a perfectly serviceable glass lid, it is just the fixing that has failed.
Steve
43,337
49,536
Steve
whatever compound you use to 'rethread' the parts dont forget to very lightly oil the threaded bolt first or even better... a wrap of PTFE plumbers tape or you wont get them apart again.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Yes one could use that but if it gets hot it goes soft, plastic metal or plasting padding might be better and then drill and tap it.
Peter
big map
4,597
182,269
Poole
You could try using a heli-coil insert. These are easily fitted with the correct tools are stronger than the original thread and not effected by heat.
A small engineering company may supply and even fit them for a small charge.
