Converting our 3 way fridge to compressor. (1 Viewer)
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Interesting way to do it. I'm just in the process of installing a Beko 240 volt fridge run off inverter and 300 watts of solar.
That's not too bad if you can switch the inverter off with the thermostat via relay/contactor. That's what I did with a small freezer I set up in my shed 👍
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Couple if questions,
Are you testing the fridge empty or loaded?
Is there a kit available for a domestic fridge with freezer above?
Thanks.
DP
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Thanks.
DP
Empty.
Yes dometic make various different kits but they're more money, I'll look for a link...
Edit; Here is what could be the freezer version, don't know how successful it would be without a door on the front
<Broken link removed>
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
I was wondering how being full will affect the the run & off times, large mass of cold stuff taking longer to warm up & cool down.
DP
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
DP
It will a bit, more so if you put something warm in, but not too much because the thermostat is fastened to the back of evaporator which will get cold quickly regardless of food temperature.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
I'll look forward to real life figures to compare with the 12 hours you did empty.
DP
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Half filled it and ran it overnight, about the same 6 start ups per hour.
Nice steady temperature :
I'll measure the amp hours used again tonight 👍
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
Can any one explain how our home fridge/freezer you can set say the freezer to -18 and the fridge to +3 I assumed it must have 2 thermostats but only 1 compressor, where the fridge/freezer in our van std Dometic absorption shares the same cooling plate in the rear with the freezer getting the lions share.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
There are different arrangements, sometimes the fridge stat operates a solenoid valve and the other stat brings the compressor on.
Sometimes there's 2 compressors (less common)
Mostly though the system is calibrated so the refrigerant goes into the fridge after the freezer and it all works out OK. Thermostat is in the fridge on this type so if you keep it in your garage over winter everything defrosts 🙄😊
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Another little job. Dometic should have done this one, but I suppose if they can save a couple of quid it makes sense 🙄😏
I wired it up through the other pole of the off switch so the battery isn't draining all year.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Exactly the same, 7ah used, 6 start-ups per hour..
Dec 22, 2018
277
220
Tasmania, Australia (northern summer in Europe)
Hymer Classic B584
Since 2019
I tried mine running the inverter in eco mode (polls for demand every few seconds and only turns on if required), but then the Fridge light doesn't work if the fridge isn't running. If it makes a significant difference and I need to conserve power, I'll do it, but I don't think that's likely.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Right that standard thermostat is ridiculous, it was switching the compressor on every 5 minutes. Fitted a little digital module this morning for full temperature control 👌
It has differential settings, compressor protection, probe offset and even alarm 😎
Positioned the thermistor to sense cabinet temperature 3°c with diff of 2.
No defrost setting but I can sort that manually.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Much better now, switching on about 3 times an hour rather than about 10 times according to the battery voltage graph.
Earlier I timed it to run 14 minutes, then off for 10 minutes so just starting up every 24 minutes. 👌
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
I've turned the controller down to 0°c (cut out 0° back in at 2°) because the thermistor is at the back near the evap, that gives a middle fridge temp of 3 to 4° 👌
Last night the fridge used about 9 amp hours. It's cloudy today but the battery is now just about recharged with 1ah to go.
Dec 2, 2019
3,591
7,778
Amersham
van conversion
Since 2019
That’s super efficient fridge, I don’t think factory dometic CRX range are that efficient as yours. It’s worth the effort you put in. Also hysteresis of two deg is pretty good for keeping a constant temperature.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Oh by the way I've upped the diff to 3°c and the compressor only comes on once an hour for about 20 minutes now so even more efficient 👍
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
On another note Richard what's the THS like is it the rugby/ cricket club looking at going in a couple of weeks 👍🏻
Yes it's very good. Quite full at the minute. Nice level grass pitches No booking allowed but you'll be ok if you avoid weekends. The club house does great burgers made by the local butcher and there's a discount on drinks if you take your club card.
Dec 22, 2018
277
220
Hymer Classic B584
Since 2019
Mine is working very well. Been in temperatures up to 39 (in France). I just wish it had an electronic temperature control like some bigger fancy fridges have. I had it turned down a bit too cold the other day. Top is fridge, middle freezer, bottom room temperature. Haven't gone below 80% battery capacity yet. It's great being able to rely on your fridge regardless of weather.
53,440
150,043
Battery was recharged by 10am 😍
Something I forgot to mention, you have a gel battery so yomay think it was fully charge it was probably 80% charged and will need at least another 4 hours of the absorbtion phase to reach 100%.
Anyway its worked out really well a great option for ageing fridges.
Richard n Ann
Jan 19, 2014
9,395
24,782
Derbyshire
Elddis Accordo 105
since 2014
Well that Chinese module thermostat thing didn't last long. It started switching on and off randomly yesterday, couldn't do anything with it so I've reconnected the mechanical stat. 🙄 I'm going to look into fitting a standard 29x71mm controller.
Hoovie
1,249
1,689
Autotrail
Very Interesting thread. I replaced my Thetford 3-way fridge with a standard 240V Domestic unit. I did contemplate fitting a compressor conversion kit but decided to go with the simple option (I did also sell the old Thetford for just a little less than the new 240V Compressor one, so that was handy).
..... Mostly though the system is calibrated so the refrigerant goes into the fridge after the freezer and it all works out OK. Thermostat is in the fridge on this type so if you keep it in your garage over winter everything defrosts 🙄😊
Ref the two comments above I quoted, I found that the thermostat being in the Fridge compartment does stop optimum Freezer performance, so I fitted a temp sensor in the freezer and I am using that information as the basis to control when the unit gets power. I have a Victron Cerbo based system and I use the value of the Temp Sensor added to the Freezer to control a relay that switches the Freezer on when one temp is reached, and then off again when another temp is reached. Interestingly, the difference between the two temps (which you could refer to as the hysteresis) is only 1C.
It may seem not enough, but it seems to work well and you can see from the graph below the fridge comes on every hour or so for around 15 minutes.
I guess the right value would be determined by a combination of how fast the compressor brings the temp down and how good the insulation is at stopping it rising again, so could vary from fridge to fridge.
I haven't disabled or rewired the original thermostat in the fridge, but just set it to MAX which makes the compressor run whenever the fridge has power - so it becomes a matter of controlling when it has power (as can be seen above in the blue line)
Be interesting how you finish your project. Hopefully the above may have been of some interest?
