- Dec 22, 2018
- 276
- 218
- Hymer Classic B584
- Since 2019
Interesting way to do it. I'm just in the process of installing a Beko 240 volt fridge run off inverter and 300 watts of solar.
That's not too bad if you can switch the inverter off with the thermostat via relay/contactor. That's what I did with a small freezer I set up in my shedInteresting way to do it. I'm just in the process of installing a Beko 240 volt fridge run off inverter and 300 watts of solar.
Empty.Couple if questions,
Are you testing the fridge empty or loaded?
Is there a kit available for a domestic fridge with freezer above?
Thanks.
DP
It will a bit, more so if you put something warm in, but not too much because the thermostat is fastened to the back of evaporator which will get cold quickly regardless of food temperature.I was wondering how being full will affect the the run & off times, large mass of cold stuff taking longer to warm up & cool down.
DP
There are different arrangements, sometimes the fridge stat operates a solenoid valve and the other stat brings the compressor on.Can any one explain how our home fridge/freezer you can set say the freezer to -18 and the fridge to +3 I assumed it must have 2 thermostats but only 1 compressor, where the fridge/freezer in our van std Dometic absorption shares the same cooling plate in the rear with the freezer getting the lions share.
On another note Richard what's the THS like is it the rugby/ cricket club looking at going in a couple of weeksJust at York THS having a 'compressor' beer teeth shattering
Battery was recharged by 10am
Yes it's very good. Quite full at the minute. Nice level grass pitches No booking allowed but you'll be ok if you avoid weekends. The club house does great burgers made by the local butcher and there's a discount on drinks if you take your club card.On another note Richard what's the THS like is it the rugby/ cricket club looking at going in a couple of weeks
Something I forgot to mention, you have a gel battery so yomay think it was fully charge it was probably 80% charged and will need at least another 4 hours of the absorbtion phase to reach 100%.Battery was recharged by 10am
Well that Chinese module thermostat thing didn't last long. It started switching on and off randomly yesterday, couldn't do anything with it so I've reconnected the mechanical stat. I'm going to look into fitting a standard 29x71mm controller.Right that standard thermostat is ridiculous, it was switching the compressor on every 5 minutes. Fitted a little digital module this morning for full temperature control
It has differential settings, compressor protection, probe offset and even alarm
Positioned the thermistor to sense cabinet temperature 3°c with diff of 2.
No defrost setting but I can sort that manually.
..... Mostly though the system is calibrated so the refrigerant goes into the fridge after the freezer and it all works out OK. Thermostat is in the fridge on this type so if you keep it in your garage over winter everything defrosts
