Converting a pop up to a high top? (1 Viewer)
bennyyorkie
74
18
Van conversion
Hi,
Just wondering if anyone has tried to convert a pop top to a permanent high top. Reanon being I've heard the insulation on the pop top is pretty much like a tent when the pop is up. Sounds pretty cold to me!
Any one got an idea of ball park figures for making the change to a toyota hiace or similar size vehicle.
Many thanks
Mar 23, 2012
9,586
32,241
sleights
c class
If you don't already have one probably a lot cheaper and easier to but a high top in the first place
bennyyorkie
bennyyorkie
74
18
Van conversion
I thought that but anted to ask all the same :)
I guess I should be asking how bad is the insulation on pop tops?
7,249
20,141
Barnard Castle, UK
Concorde Concerto
I am a but confused here, does the pop top you want to convert have 2 sleeping areas, how many berths do you need?
If you want to convert it to a high top then don't elevate the pop top and it will be warmer, a pop top with the top down will be similar to a high top.
bennyyorkie
bennyyorkie
74
18
Van conversion
Sorry, my bad.
I only need it for myself and my yorkie so a 2 berth would do. I can understand the pop up will be down when sleeping, just a but cautious for heating the van during the day. I've no experience with them Im afraid.
7,249
20,141
Barnard Castle, UK
Concorde Concerto
Depending on the price of the van it would be waste of money converting it, just leave it down all the time apart from summer especially as you have another sleeping area, if it doesn't leak then just leave it as it is.
Is it a warm van with the pop top down? Because if is isn't then the rest of the insulation is not very good and it would be best just swapping the van.
2657
One big advantage with pop tops is that you can get under most height barriers.
23,863
134,518
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Search for Reimo roofs . I looked earlier this year but the cost wasn't too bad ex-factory , about 500ā‚¬ but it was the transporting it which was going to cost the most.https://www.reimo.com/en/G-campervan_conversions_shop/good-roofs_for_camper_vans/
bennyyorkie
bennyyorkie
74
18
Van conversion
Just wondering if you are cooking during the day, or jsut want to have a bit of space to stand up....does having the pop up seriously change the temperature in the van? Or is it barely noticeable?
7,249
20,141
Barnard Castle, UK
Concorde Concerto
If its cold and you have the pop top up it will seriously change the temperature, its only a bit of canvas like a tent.
11,939
9,125
Hi BY the pop top in your size vehicle would be a lot more desirable .......having said that you can buy fiberglass tops for around Ā£1000 ....easy enough to cut out hole and fit but again I would recommend buying a van that already has a high roof fitted
Reactions: Jim
1,261
2,387
Wellington, Telford, Shropshire
Since 1977
You don't say what vehicle you are considering converting from pop-top to high-top. If it's a VW T4, T5 or T6 with a Reimo pop-top or one with the same size roof aperture then changing to a high-top should be quite feasible. I've converted five VWs with high-tops, all but one with a Reimo roof and believe that the reinforcing frame in the aperture is the same for either styles of roof. The vehicle in my avatar is NOT a Reimo roof, it's a factory high-top LWB VW T5.
Rod
4,774
25,108
B&NES
since 2007
If you want a high top van, buy that in the first place. It has its advantages, so try it and see if you like it.
Don't waste a good campervan with a proper elevating roof by sticking a high top on it.
In 10 years of ownership we put the roof up when we wanted to. Only in sub-zero conditions we slept with the roof closed, and stayed warm enough with the heating off. In hot weather the canvas sides are a huge benefit and make it easier to sleep without a fan. It never leaked even in heavy rain storms.
1,372
4,149
Cheshire
Been around the block a few timesšŸ˜‰
Excellent post (y)
962
971
Malvern
Hymer B525 2006 A cl
We found that rhe pop top was fine down to about 10C but we then bought a silver screen. Cost about Ā£150 and fixes with a bungee round the pop top. Sits inside the overhanging roof so keeps the canvas dry also if there is driving rain. This made a big difference.
