Comfortmatic Gearbox Load assist button (2 Viewers)
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
Can anyone advise if the load assist button is on or off when the E is displayed next to Auto on the display? I dont have the Gearbox supplement and the only one I can see on line is referring to the Up Button.
18,033
48,138
I've never bothered with it and as I've never seen an "E" illuminated then I'm sure the answer above is correct. :)
If on a steep hill such as a pass I just put it in manual and choose the gears in the old fashioned way. Both going up and coming down. :)
Reactions: f6c
Mr Colpot
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
Thanks for the replies - I have always had it on!
I normally just let it do its own thing on hills apart from sometimes changing up when going downhill.
Will run with it off from now on (we tend to be 3320kgs in holiday mode so dont think I need it on?)
May 31, 2015
11,685
44,541
Ducato PVC
Getting Better
I've experimented with it many times and have come to the firm conclusion that it does....absolutely nothing (n)
53,476
150,187
E? mine has the same symbol as on the switch, it's on when lit. You have to select it each time after starting the engine as it turns off with the ignition.
I find it works really well, holds the gear much longer before changing up and when desending holds in a low gear longer I use it a lot. The heavier the van the better it works.
May 31, 2015
11,685
44,541
Ducato PVC
Getting Better
Yes, no E but the symbol, lights up Lenny but it does seem to do nothing...? I know my way around mechanics and would definitely be aware of the slightest difference, I tested many times and have left it on straight after start-up for hours and no difference...?
18,033
48,138
I must give it a try. :)
53,476
150,187
Won't notice much difference unless you are on a mountian, and if you are running your van at 3500kg it won't make much odds but when you get up to 4000kg it is very noticeable.
May 31, 2015
11,685
44,541
Ducato PVC
Getting Better
I'm 4250kg but probably running at 3900-4000kg (haven't got the wine onboard yet) and it was when I went over the Swiss alps in may that I gave it a good testing and as said no discernible change..:(
Ps. I've got a 2012 B544 2.3 150bhp comformatic
I'm seriously thinking on getting it re-mapped when I get back home..
Reactions: f6c
53,476
150,187
We run around 3900kg with a 150 Comformatic, on theExsis running at 3600kg didn't notice a lot of difference on the new van a marked difference. Maybe they have changed the software and new ones work a lot better.
May 31, 2015
11,685
44,541
Ducato PVC
Getting Better
But on the roads of France I've calculated that I'm getting around 28mpg brim-brim.... no tolls (I don't do them) and in no hurry 55-60mph which I think is pretty good...:D2
Steve and Denise
5,294
14,093
Spalding LINCS
A Class Carthago
Since 2008
Ours has an E next to the gear number also a symbol on the bottom of the speedo opposite the cruise control light.
I use the up switch all the time 3.0 180 tag once set it stays on even when the engine is stopped and restarted it does hold the gear longer which suits my driving style also the van is 5000kg.
Emmit
8,034
17,754
Pilote Explorateur
Jan.2014
Just remember.
The "R" on the Gearstick does not mean 'Race' when you are trying to outgun the Sportscar that's in the outside lane at the traffic lights.
Aug 26, 2008
4,763
24,983
B&NES
since 2007
I use the "up" button quite often, now that I am more familiar with the Comfortmatic box. Otherwise it changes up too early for my tastes, and feels like it is labouring in too high a gear up most hills. On flatter roads I turn it off again for (I hope) better economy.
I haven't noticed the "E", only the green symbol.
