Clutch and brake pedal blockers security systems (1 Viewer)
D
DL42846
I have just seen on FB motorhome site a Clutch and pedal blocker which some guy has made himself. I have done a search and can't find anything similar on the market.
Does anyone know or have such a thing that they are happy with. I did a search on eBay but the ones on there look very flimsy and don't have very good reviews.
Aug 27, 2014
1,910
3,935
Shropshire
McLouis Tandy 640+
Since 2014
I've got (and use!) the clutch claw that Steve linked to. Very sturdy bit of kit, though I did have to tap the threads out of the base plate before I could use mine - the plating was a bit heavy and had clogged the threads up.
I think it would be an absolute pig to remove without the key. Even if attacked with a cordless angle grinder, the only thing I can think of that would remove it, it would take time, noise and effort to get it off.
17,635
43,369
I am not at home on my laptop right now or i would post a link to a pedal box sold by garrison locks. Very secure and substantial
andy63
4,672
15,018
south shields
since 1990
Hi.. heres a picture of the sort of thing i made up for a ford transit... the one debs got was a bit different... it didnt need the legs..
They are easy enough to make if you have access to welding and drilling facilities..
I use a roller shutter door lock welded on to some flat bar..
They are not as bulky and heavy as most of the commercially available units... bit mine is easily stored in the door pocket..
Andy
And fitted over the pedals
D
DL42846
I was thinking of something like the attached
Hi, Thanks, No problem I will check them out.
Andy
Andy
Andy
Wombles
10,808
11,132
SW England
A few years now
Anything you choose is a deterrent so worthwhile. We have had a couple of Clutch Claws for the last few years for car & motorhome & ideal as when we have changed vehicle make & model each one could be readjusted to fit so no need to buy new. If anyone is considering buying one then 10% off with code MHMADNESS here https://www.nkgroup.co.uk/product/clutch-claw-in-car-security-device/ .
Deneb
1,598
2,334
Europe
PedalBox is about the best, as above.
Not much point worrying about whether clutch claws or similar will resist an angle grinder when the pedal arms they're being fitted to are made of plastic!
The design of the PedalBox makes access to cut through the pedal arms much more difficult unless you were to remove the lower dash panel, but even then you would be left with stumpy little arms that would make driving the vehicle extremely difficult.
