Can’t remember the last time we didn’t use our levelling ramps.
Most times with my van..Rear is higher than the front...BUSBY.Thanks, I guess my question is really more about leveling blocks, how often are you parked up on an area that is so inclined that you need them?
You must have had a dodgy pitch. Was the cliff already subsidingI find them wonderful to fill up much needed boot space...........................Used once on a sight guess where Kannon Fodda
It's the same as a manual when left in gear more secure than the pawl that holds an auto in park. Also it shouts at you if you stop it in neutral, you are supposed to stop it in gear.be very aware that the auto box fitted to fiat ducato vans up to last year are NOT REAL AUTOMATIC they are robotised manual. Therefore the gearbox does not hold the van when parked
Oh good as it hadn’t occurred to me not to have my handbrake on! Our drive’s on a slope so I tend to always leave all our vehicles in gear with the handbrake on at home. The cars are all manual mind.There is a view that you should still use the handbrake on automatics and that you should apply the handbrake before selecting 'P'. This helps relive the constant pressure on the parking pin in the automatic transmission - or so have have gleamed from Google! It makes send plus 2 independent forms of braking have to be better than one - even better with chocks!
In Germany if over 3500 kg chocks are required if parked on a slope.
