Nutz1
I have just bought a new Chausson 610 flash - can anyone advise me on the following points, the booklet I was supplied isn't good at all;-
1. To drain off the water tanks - what is the best way of doing this ? I can only see a valve right underneath? I opened both outlets and switched the pump on - but not sure that was correct
2. Webasto heating- does it run off both Diesel and hook up electric- if so where is the switch to move from one to another ?
3. Where so I manually use the crank for the electric bad?
Thank you for your help
