changing ceiling light bulbs (1 Viewer)
golly
2,006
69,657
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I looked at the ceiling lights in my Auto sleeper Surrey with a view to changing to LEDs expecting to find halogen bulbs, however the ceiling lights have mini fluorescent tubes (see photo). Doe's anyone know what wattage these are or has anyone managed to change these for LEDs.
Thanks John
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
It looks like this series:
http://www.osram.co.uk/osram_uk/products/lamps/compact-fluorescent-lamps/osram-dulux-l/index.jsp
Note they are 230V lights so there will be an inverter in the existing lamp housing. You would need to bypass that if fitting LEDs. I have some fluorescent tubes in my Hymer (older style straight tubes, not folded like yours) and have decided to leave them alone.
There was a post on this subject about a week ago.
golly
golly
2,006
69,657
HYMERCAR PVC
since August 2009
Yes, the van wiring goes to some sort of electronic wizardry :whatthe: I thought it was some sort of starter, but it would make sense if it were an inverter. If it was drawing a low wattage I would just leave them, but I cant find any marking on the tube.
As you probably guessed I an electrical numpty :Doh:
JeanLuc
3,304
2,199
Warwickshire
Broken Link Removed was the recent thread. It contains details of how I converted our fittings in our previous van. They were definitely 12v.
I realise the existing lights are on the 12V circuit, but the lamp is a 230V item. If the Autosleeper fitting is like those in my Hymer, there is an inverter circuit inside the lamp fitting that converts the 12V DC into 230V AC in order to power the tube. LEDs can, of course , be fitted by bypassing the inverter circuit and, possibly, reconfiguring the on/off switch if that is integrated with the present circuit.
GJH
29,450
38,827
None, now sold
2006 to 2022
OK. I thought it was a starter as well but I'm happy to believe it was an inverter. I note that I referred to it as a "ballast" in my posting on the other thread so maybe I got the terminology completely wrong :Smile:
However, conversion is by bypassing that circuit so that the wires from the LED holder go direct to the switch.
Ken's advice to check with Aten Lighting is sound. I did so before I converted ours and bought the LEDs and holders from them.
golly
golly
2,006
69,657
HYMERCAR PVC
since August 2009
Thanks Graham, the fitting you used looks as if it would fit, two connectors to the tube, but I am a bit hesitant as I thought it would just be a straight swap the same as the spot lights were. I have emailed Auto sleeper to see if they can advise.
John
17,635
43,370
thinking I might write a "how to" thread with photos on how to convert a fluorescent light fitting to LED. yes i realise its relatively simple but lots of people are confused and worried about doing it
would there be any interest?
golly
golly
2,006
69,657
HYMERCAR PVC
since August 2009
That's a yes from me,:thumb: would be very useful.
John
GJH
29,450
38,827
None, now sold
2006 to 2022
Good idea. I wish I'd thought of taking photos when I converted ours as they make an explanation so much simpler than pure text.
17,635
43,370
will sort the bits and bobs out in the next couple of days then and hopefully get it done at the weekend:thumb:
11,956
16,570
Those fluorescent tubes are usually pretty efficient, so may be limited benefit from replacing them.
The tubes are normally approx. 8W so there are substantial benefits from changing to LED. Conversion is simple: remove everything inside the fitting except the switch. Connect your chosen LED module to 12V (via the switch) and earth. I used these:
Use 2 or 4 panels per light fitting depending on how bright you want them. They're available in warm white or brilliant white. Note the price is for ten panels. They have double-sided adhesive on the back.
43,337
49,540
I replaced all 9 twin tube 11w (22w per light) fluorescents to 20w led strips by simply cutting the wires at the existing inverter board and connecting to the led strips.
Didnt need to remove the existing inverter gear...just the tubes.
Near as damn it 2 amps per original light with inverter losses reduced to less than 2 amps with all 9 lit.....a massive saving of 16ah
11,956
16,570
That's just so untidy - and think of the effect on your payload of all those inverter boards ............. :Eeek::ROFLMAO::ROFLMAO:
golly
golly
2,006
69,657
HYMERCAR PVC
since August 2009
Had email back from auto-sleeper. Flurescent tubes are 8W. So my next question for the electrical wizards is - will the amps for each light be 8w divided by 12v = 0.6amps, even if the tubes are 230v tubes with the supply inverted up. if they are 0.6amps each its hardly worth changing. or have I got it totally wrong.
John
JeanLuc
3,304
2,199
Warwickshire
John
Correct - plus a bit for inverter circuit losses, so probably about 0.74 amps
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
What's the consumption of these replacement panels?......I have looked but can't find any indication. Thanks.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Remove lamp, remove lamp holder, remove gear tray (although it looks to be welded to the housing).
Then disconnect the 12v supply to the existing fixture and hook up to one or two LED SMD panels like this... Broken Link Removed
:thumb:
oh too late!!!
8,164
11,229
Yr Wyddgrug
Hymer B678DL
Can someone please check my maths:
Assuming the LEDs are wired in parallel and each LED uses .020 milliamps * 48 = 0.96 ma * 12v = 11.52 Watts per panel. This is higher than the tube consumption. Or have my figures/thoughts gone awry?:cry:
Many thanks.
11,956
16,570
They're not wired in parallel - they're in a series/parallel arrangement. I'll try to measure the consumption of one of my spares. Bear in mind they are very bright - one panel produces considerably more light than an 8W tube.
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
Tony,
Did you get the opportunity to measure the consumption?
Thanks.
17,635
43,370
I haven't forgotten my offer, just waiting for some more lights to get here from hong kong. could buy in the uk, but twice the price. so if it takes an extra week, it might be frustrating but at least i saved some cash for more booze:ROFLMAO:
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
I eventually ordered some of these panels and measured their consumption:
9 Watt Florescent bulb using P=VI equates to 0.75 amps
48 Led panel = 0.245 amps
So three Led panels for the price of one florescent (so to speak):thumb:
