change petrol engine to diesel (2 Viewers)
Jun 4, 2012
104
15
Holbeach st Johns (Spalding)
C class Kon-Tiki 645
9 years. 30 years as a tugger
has any body changed a petrol engine to a diesel one.
this is for a peugeot talbot 1991would a 2.5 tdi fit ok. answers please. regards ray
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Its not quite as simple as you think. First the gearing will most likely be wrong, so you will have to change the gearbox as well. Secondly a diesel engine wont run from a petrol engine fuel tank as there is no return or swirl pot in it. There are also electrical issues that need sorting ie heater plugs. It can be done, but its not for the faint hearted.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
On a 1991 van its not worth the cost frankly, unless you know what you are doing and then its debatable.
You also have the insurance problem of modification.
Peter
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
As a DIY project yes its doable with all the right parts, if your hoping to just swop the engine you had better go back to the drawing board
Paying a Garage to do the conversion would not be cost effective even prohibitive, assuming you found a Garage to take it on
rainbow chasers
3,680
1,725
Mid Cornwall
Various
It would be less hassle to convert it to LPG, you will get similar economy especially when you consider diesel is 10p more a litre!
You can pick up a hom conversion kit for less than a diesel engine would cost you. four cylinder conversion ready done at a converters wouldn't cost more than say, £600ish.
Cheaper, less hassle and you get a little off your car tax.....and you don't have to worry about emissions zones (once you change the log book)!
BobProperty
271
32
Stockport
If you've blown up your petrol engine and have a spare diesel one then yes, it's worth it if you can do the work yourself. If you are thinking of doing it to save fuel then go lpg. All the engines fitted to Talbots are really old tech and the diesel won't save you much over the 2l petrol.
.... Secondly a diesel engine wont run from a petrol engine fuel tank as there is no return or swirl pot in it.....
Oddly, the Talbot uses the same tank petrol or diesel (IIRC) and there is a return on the petrol.
:Eeek: <---- that's the nearest I can find to a geek smiley.
mid4did
526
728
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
swapped a petrol engine for a diesel ? yes but you got to have a plan if you,re seriously considering it.i have done it way back put a 1500 bmc disel including g- box into a cortina :Smile: problems were first engine mountings had to be made up, bulkhead modified for the starter/ alternator , propshaft shortened and balanced, exhaust was quite good , had a chrome plated sidewinder across the front bumper:Smile: ,i was in the garage trade at the time and had a friendly metal fabricator obviously different models to what you envisage but you will get similar problems,if youth is on your side go for it :thumb:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
That takes me back a bit. Long before diesel cars became popular in the UK I did some very wierd conversions. The first was a Perkins P6 into an Oldsmobile 88, then a 3 litre BMC into a Humber Hawk. The last one was a Mitsubishi 2.8 turbo into a Volvo 144 estate. Then I found diesels were becoming available here in the UK built by the manufacturer. I still thought mine were better even though I never needed 1st and 2nd gear :Doh:.
con-tiki
457
187
Leeds, West Yorkshire
A class Hymer
since 2009
I had a 2l petrol engine on a '91 kontiki...I thought that the diesel would be better. Apparently the petrol engine was better than the 2.5 non tubo diesel.
Shirl
Scout
3,959
121,359
South Yorkshire
chic c line
I think tommy cooper did it once
he was asked how, he said
"just like that"
oh dear Im of to bed:sorry2::imoutahere:
Madmark62
602
546
Wakefield West Yorkshire
Winnebago Lesharo
I`m a newbie
Why on earth did you put a 1500 BMC diesel engine in a Cortina?
The BMC is only 30 bhp , needs bloody ages on the glow plugs, which are a bugger to extract, they smoke like a wood stove, I know because we have one in our narrowboat and it is not that great in there either :ROFLMAO::ROFLMAO:
mid4did
526
728
N.somerset
Because we could:ROFLMAO::ROFLMAO::ROFLMAO:and diesel was cheaper,sounded like a tractor,engine it was from a van then ended being marinised in a boat,as you know its a very popular marinisation engine,before the 1622 and 1800 versions.Happy Days:Smile:
raypat100
Jun 4, 2012
104
15
engine change
Peter
Hi Peter Thanks very much for the info on the change from petrol to diesel, Could you please advise on fitting LPG. to the same model cost etc. Many thanks Ray Scott
43,332
49,500
I can see a grown man doing a lot of weeping......
not sure if the van is front or rear wheel drive but the following are possible scenario's and very likely.
engine wont physically match gearbox....so either an adaptor plate needed or change both engine and box
existing drive shafts or prop shaft wont match new gearbox....replacement shafts needed.
prop shaft not a real problem but replacement front shafts wont match existing front hubs....replacement hubs needed (if they fit the existing suspension arms)
gear selector mechanism different to existing.
rear wheel drive....rear diff ratio not compatible with replacement box
clutch actuation may be different. (hydraulic/cable)
just a few of the mechanical problems you may encounter.
raypat100
Jun 4, 2012
104
15
engine change
Hi pappajohn
thanks for the info. I now realise that changing from petrol to diesel is not an option. Thanks to all the info from all the funsters. I am thinking down the road to LPG thanks again Guys. regards Ray Scott.:Doh:
mid4did
526
728
N.somerset
Hi pappajohn
Good luck in whatever you decide is best,another thing was going to be the noise!! diesels aren,t the most silent engines.The 2.5 di is a good engine thou.....???
43,332
49,500
Hi pappajohn
go for a sequential system.
starts on petrol, runs on petrol until warm then automatically switch's to LPG.
more expensive option, but easier starting and far kinder to inlet valves...LPG doesnt contain any lubricants.
11,932
9,092
Pesonaly on a old 91 van I would not bother with either changing to D or gas unless you intend to keep it a lot of yrs you will be wasting your money :Eeek:GAS CONVERSION WILL COST AROUND £600/800 (thats a lot of petrol ) and the D swap could well be a proper head ache -- I swaped a 3 ltr tranny petrol to D yrs ago and that was stright forward useing exhisting gearbox and fuel tank :winky: no idea if it is a stright swap on a Fait etc though
terry
