No Lenny your supposed to eat the wax not rub it onMy sh*t has super sticking power tried the Collinite trick didn't make much difference.
Just one thing bothers me about the ceramic lining. Should the toilet be used with the blade closed the contents of the bowl will naturally reach the same level both on the inside and the outside of the insert since only the top of the insert is sealed. Does to not follow that when the bowl is flushed only the inside of the bowl will be flushed and any detritus and liquid which has gone between the insert and the original plastic bowl will stay where it is. I may be wrong but if I am not there will be a fair amount of germs lurking in the toilet and probably an accompanying pong which might be difficult to eradicate.
Just seal the bottom no probsJust one thing bothers me about the ceramic lining. Should the toilet be used with the blade closed the contents of the bowl will naturally reach the same level both on the inside and the outside of the insert since only the top of the insert is sealed. Does to not follow that when the bowl is flushed only the inside of the bowl will be flushed and any detritus and liquid which has gone between the insert and the original plastic bowl will stay where it is. I may be wrong but if I am not there will be a fair amount of germs lurking in the toilet and probably an accompanying pong which might be difficult to eradicate.
Just setting the aim up JimWould you call that a "Bottom" view Dave?
I agree
