Minxy
- Aug 22, 2007
- 32,488
- 66,010
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
Just thought I'd update on some of the issues we've had which I may, or may not, have mentioned previously in other threads such as those below:
Well, it FINALLY went in for it's habitation service on 11th December and we collected it on 18th December, below are the things we asked them to sort for us under warranty.
At some point we'll get the stuff back in it so I can have my conservatory back ... Christmas dinner isn't gonna be had in there this year!
Poor service from dealers
Sometimes with the best will in the world, ordered parts are not forthcoming and this makes people who may have just paid huge sums of money for their vans, rightfully very cross and wanting to tear strips off dealers. I know there are rogue dealers out there who, once you have collected your...
www.motorhomefun.co.uk
Hob: It wasn't sitting 'flat' on the worksurface at the front where the control knobs were, ie it had a bow in it, it also moved back/forth when the glass lids were lifted so wasn't fully secured into the worksurface itself, also the glass lids never aligned when in the vertical position (ie open), so it looks like we had a 'wonky' one. This has now been replaced by the dealer with a new one.
Fresh water system: we had a lot of issues with the taps spurting, glugging, with lots of air in the system which we couldn't get rid of completely. I discovered air was somehow getting in the pump filter clear plastic 'dome' as the water could be seen draining out of it. It has finally been resolved by the dealer who found that the actual filter casing had a hairline crack in it so they have replaced it all - apparently this isn't the first one they've had like this so they suspect there was a badly manufactured/faulty batch; on all the ones they've fitted new ones to none have had to be replaced again.
USB socket: The USB socket on the lower left of the dash nearest the cab's passenger door was broken as the small plastic flat piece that holds the external USB in place within the slot was missing, they have replaced it with a twin socket.
Passenger door: This clunked a bit and sometimes stuck so not always easy to open, they've now adjusted it so it works as it should.
Habitation door: we noticed shortly before we were to take it in that both bottom corners of the hab door painted aluminium frame were bubbling, this has been cleaned up and repainted so hopefully won't return, none of the lockers had this issue fortunately.
Small over-sink cupboard & TV cupboard: the doors rubbed on the side walls when being opened/closed - they adjusted these.
Washroom door: this sometimes rubbed so has also been adjusted, I assume part of it was down to temperature changes but obviously it should open without a problem whatever it's like.
So all well and good? NOPE! Unfortunately we have some 'damage' ... whoever was working inside has somehow put a horizontal 'scratch' roughly 10mm wide on the left side of the washroom door frame, it's not very big but as it's just at eye height and where you look when opening/closing the door we'll see it every time we use the washroom! We've no idea how it's happened and neither has the dealer, it could simply have been from something on a piece of clothing, but however it's happened we're not best pleased as you can imagine - last time it went in for a socket issue it came out with a ruddy great scratch down the garage door although they did compensate us for that (we might get it sorted one day when we can get it booked in somewhere!). In order to sort the scratch they're sending me some 'wax' sticks so I can see if I can 'blend' it myself, which is what they'd do, as there's no way we're doing a 5 hour round trip for it. We'll be giving it a good looking at this week to ensure that there's nothing else ... I hope not as I'll go ballistic.At some point we'll get the stuff back in it so I can have my conservatory back ... Christmas dinner isn't gonna be had in there this year!
