- Oct 16, 2008
- 16,422
- 98,044
- Nearly aint got one.
- Caravan & motorhome 45 + yrs
Can it? The bbq point is on the low pressure side. You meant to back feed on the high pressure side before the regulator. Like Mike mentioned, via fill up point with a hose. Gas it sells this hoses for about 20 quid.If it has a BBQ point gas can be fed in through that
On ours we can just take the hose off the right hand bottle with the easy release screw fitting and connect to a bottle
No.If filling from bottle into filling point would the bottle empty or equalise, 50% in bottle 50% in van ?
The link provided by Robert Clark fits to the filler inlet Mo so will do tanks and bottles… it’s made for the job and is safe and will be the easiest to do…Thanks, David.... but what about a fixed underslung tank..???
Not so safe when a child playing knocks the cylinder over or it’s hit by a mowing machine, not to mention the owners forgetting it’s connected and driving awayThe link provided by Robert Clark fits to the filler inlet Mo so will do tanks and bottles… it’s made for the job and is safe and will be the easiest to do…
Let’s just ban gas barbecues then…Not so safe when a child playing knocks the cylinder over or it’s hit by a mowing machine, not to mention the owners forgetting it’s connected and driving away
High pressure external connection is actually not a
good plan at all .
Also what about if a helicopter lands and the down draught blows it over, how many what ifs do you do ?Not so safe when a child playing knocks the cylinder over or it’s hit by a mowing machine, not to mention the owners forgetting it’s connected and driving away
good plan at all .
The safest way has already been suggested - use a BBQ point with a regulator on the bottle. This is what we did when we had a problem filling our tank in Spain. It was recommended to us by the company which installed the tank when I contacted them by phone. Fortunately gus-lopez wasn't far away and he very kindly lent us a bottle and regulator. If you don't have a BBQ point they are not difficult or expensive to fit.Thanks, David.... but what about a fixed underslung tank..???
Connecting an external bottle directly to the filler point is a more elegant solution I believe as it allows you to use the bbq point at the same timeI think that sign is just to stop anyone filling it with high pressure gas. Coupling a bottle with a regulator to it is safe according to the suppliers of our system.
Couldn't you just connect the bbq to the external cylinder directly?Connecting an external bottle directly to the filler point is a more elegant solution I believe as it allows you to use the bbq point at the same time
YesCouldn't you just connect the bbq to the external cylinder directly?
Yup.With an "On Board LPG Tank"........... is there a way to couple up a free standing gas bottle..?
Just reading about all the places that are running out of gas and how hard it is to get in some area`s, got me thinking..
Can it be done and how easy to do..??
