RichardandKaren
So, recently my Truma ( older C6002) has been playing up. More often than not ( but not always), when it's on my drive at home and when I put the heating on it locks out and the red light comes on the control dial. This is whether it's on hook up or on leisure battery. However, if I take the van even for a short 10 minutes drive then when I get home the heating comes on first time ( on ehu or leisure battery) and works perfectly! Then a day or two later the same problem reappears and, again, a short drive sorts it out! My own conclusion is that this is some sort of loose electrical connection maybe but, if that was the case, why would it not work a day or two later when it has been standing still on my drive? Also, thought about could this be a problem with the gas solenoid getting bunged up and a drive somehow clears it a bit? By the way the hobs/oven/fridge all work perfectly normally on gas and the gas cylinder is about 3/4 full. Any suggestions?
