Any recommendations for a camp table (For eating outside) to store in the garage . Enough for 2 - 4 people . Not an exciting thread but u might have some suggestions ?
Thanks what’s the net underneath for ?
This one gets my vote. We went through four before we stumbled upon it. It ticks every box IMHO.We've got a Eurohike rolltop table.
Features
- Lightweight aluminium – makes it easier to carry and improves life span.
- Roll top surface – easy to pack away.
- Adjustable leg – for the correct height and a level surface when using on uneven ground.
- Collapsible legs – makes it easy to pack away.
- Complete with a handy carry bag - makes it easy to move around.
- L110 x W70 x H71cm – when open.
- 109 x 12 x 21cm – when packed.
- Weight 5kg
Features
- Weight 5kg
Another vote from me, except mine has black slats. Lasted yearsWe've got a Eurohike rolltop table.
Features
- Weight 5kg
Resting your appendage? Depends how camp it is I suppose.Thanks what’s the net underneath for ?
Us too - like itWe've got a Eurohike rolltop table.
Features
- Weight 5kg
Hi Nasher, I would like to use the table and support which came with our van (Autotrail T680 2018 model), to use it outside. But I've been unable to confirm whether my support would fit into the Fiamma base. The support is approx 57mm diameter which tapers at the end to approx 54mm. Do you think it would fit?I bought a Fiamma tripod so I could use the Moho table outside :
But the tables posted on this thread look way better and in some cases for less money
Don't you think you should have bought one instead of just taking someone else'sWe have the Kampa table hi lo pro , can be adjusted in height and leveled easily, uses finingvtable or coffee table, walked around many sites , looking at other peoples tables until we found this one , so useful.
I'll order one. Thanks for taking the time to do some measuring.I've just check my support (ooh err missus) and it's the same dimensions 54 at the bottom tapering to 57.37
So yes it will fit fine
