buzzing from the electro block underneath the passenger seat
Welsh girl
Globecar
Since 2004
I have a buzzing from the electro block underneath the passenger seat in my globecar. Intermittent buzzing rising to a screech. When the engine is running. The man in the garage had a look and finds loose wire. He said that i can pay a auto electrician £80call out then £60 an hour to find out why. Can anyone shed a light on why this is happening?
I have recorded this but cannot upload it to this thread as my phone won't let me.
Upload to YouTube then link it to here.
I've uploaded it to utube but how can i link it to here?
Just found it.
The electroblock is vibrating when the noise is happening
I don't think this is something you can tackle yourself. Unless it's caused by a bad connection in the wiring block connector.
The relay (if it is a ralay) could be buzzing (switching on and off very quickly) for any number of reasons.
quite a common fault and the relays soldered to the pcb need replacing as the internal contacts are scorched. there are a couple of firms can repair these on a couple of days post turn around. apuljack or aandn spring to mind
Yep relay buzxi g probably a fault on the circuit driving it.
Talk to Applejack engineerinh or A&N Caravans, not sure if A&N still repair EBL's since Alan passed away, but they may have an exchange unit.
I'm in Devon, can you suggest somewhere nearer me I've googled the names you suggested and all are up north. Just found that apujak are in Somerset. I'll contact them Tuesday. Thanks guys, you've come up trumps again!
you unplug the ebl and post to them
Yes they will sort you out they have standard fee for repair.
