This is under the seat connected to the Electroblock bl2 pin 1. Is it a fuse or just a joint please.
Hardly surprising with a joint like that. Should be a male and female spade joint, that looks like 2 x female and a male coupler.Looks like just a burnt joint, look at one behind, it`s appears the same.
Bad connection by the looks of it
Agreed. Am I right in thinking the red wire goes to pin 4 of the 4-way connector on the EBL?Looks like just a burnt joint, look at one behind, it`s appears the same.
At least you haven't made the same mistake as me. Driving back from Germany through the Netherlands I noticed a burning smell, but only when the engine was running. I concluded, logically, that it was a slipping clutch, and drove very carefully back to the ferry in Rotterdam. I took it straight a local lorry place where I get the MOT, and they were happy to put in a new clutch for a reasonable rate. Then driving it home, there was the burning smell againThanks everyone, we bought it brand new so is original, we smelled burning so investigated, appreciate your advice x
The wire looks OK for 16A over a short distance and hasn't suffered any ill-effects up to now. It may get warm to the touch but won't continue to get any hotter. Using a thinner wire into the Electrobloc is a common way to overcome the fact that the Electrobloc plug pins aren't designed to accept anything thicker.I have changed the joint but now the short piece of wire heats up al lot when the fridge is on and engine running ,it’s pulling just over 16amps I have a cheep meter I carry with me But I’m no electrician. I am a bit worried about it catching fire. Its definitely pin 1 block 2 on the five pin connector .
Is there anywhere I could take it to be fixed.
