brand new apache 634 (1 Viewer)
Shrimp
May 27, 2015
3,986
33,438
Bedfordshire, UK
Hymer B584
Long time
We weighed ours quite a while back we loaded it with as much winter stuff as poss, water etc.
Found we still had some spare.
then we up-plated it to 3850 so we know now just how much stuff we can carry and still be ok.
JockandRita
11,462
150,157
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Where would I get it weighed folks
I’m in NG17 Area
Here you go Baden87.
Weighbridges
There are 14 public weighbridges in Nottinghamshire where you can check the weight of vehicles or livestock up to three tonnes.
See weighbridge locations and contact details [Word].
We weigh ours once a year, usually on our way across the water, when in full holiday mode.
If you present yourself at a VOSA weighbridge, they will print off a ticket, but not charge you. The problem is, that if you turn out to be overloaded, you will have created yourself a problem, if you can't dump enough water, or redistribute some of the load to take you under. :(
Good luck,
Jock. :)
Lenny HB
53,430
149,981
On the coast in West Sussex
Hymer B678 DL
Axel weights are what can catch you out. You might be ok over all in weight but overweight say on the rear axel. The police do prosecute on axel weight as well as total.
And if overweight on both axles and gross you get 3 fines. A guy in the Hymer club got done on one of the M1 services a few years ago got three £60 fines.
Jonno1103
1,329
1,471
Harrogate
F Line F70
Since 2012
Roller Teams 2020 brochure has removed all of the MIRO and payload figures from the tech specs, they just give the gross now... Interesting.
A 2020 Apache 634 only has a 350 kg payload when up plated to 3650 kg. It only has a 60L fuel tank too.
As a scenario, an up plated 634 with an engine upgrade, auto box, media pack, tank heaters, 2nd battery, coffee table and 5yr body warranty increase with cost you £69,597 and give you a maximum payload of 320 kg's...
Lenny HB
53,430
149,981
Hymer B678 DL
Stupid money not even an A Class, I only paid a couple of k more than that for my Hymer with 135Okg payload. And I had €15k of options. But that's why I buy in Belgium. ?
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
My Rapido has been uprated to 4000kg but the front axle is tight, though not overweight, even though there's really nothing much I can move at the front. Its the larger 3L engine that does it. if it had a transverse bed with garage rather than the washroom across the back I could load heavy stuff to move the weight backwards. The best I can manage is a back box and obviously the weight that can carry is limited. I must remember to move the jack from under the passenger footwell, that must help a bit, especially if it goes in the back box.
Lenny HB
53,430
149,981
Hymer B678 DL
You could fit uprated front springs assuming your front axle is 2100 that would update it to 2300kg.
Jonno1103
1,329
1,471
Harrogate
F Line F70
Since 2012
Judging by the payloads of Trackers and Apache's compared to the similar specced but lighter and nearly 10k cheaper Imala's I have a feeling Auto Trail will be phasing them out sooner rather than later. The new Euro designed Tributes will also effect their sales too.
Lenny we only wanted a small two berth and lose the trailer we had to have with our Tracker hence the reason we sold it for the small Pegaso - still 3500kg but the payload is more than double.
Regardless of the build quality debates, British vans will simply loose out to European built vans at higher UK prices offering specific UK appealing options (ovens etc) simply because they have a lot more usable payload.
Aug 18, 2011
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
Should
what makes you think its overloaded busby? does every one weigh there motorhomes before going out ?
Should weigh it at least once when it is loaded with all your goods etc that you tour with,plus of course the driver and passengers.Ignorance is no defence if you are pulled and weighed..BUSBY.
JockandRita
11,462
150,157
Lincs/Cambs border
N+B Flair 8000i
Should
I totally agree busby, but I'm not sure that Baden87 sees it that way, judging by the lack of response to advice from others. :(
Jock. :(
MikeD
3,936
3,697
London
IH PVC
Since 2012
Jock. :(
Alas I think a lot of people will see it that way. Ignorance is bliss in some cases.
Also if they know they are overloaded they may feel they have to something about it and that may come very hard if they only have a 100kg or so to play with.
Aug 18, 2011
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
Jock. :(
There must be hundreds of motorhome on the road running illegally either being overloaded or driven by driver's without the correct licence.Met two in Spain who had not got a clue about updating their licence at 70 to drive their over 3.5 tonne vans.BUSBY.
JockandRita
11,462
150,157
Lincs/Cambs border
N+B Flair 8000i
I'm sorry, but that is just totally irresponsible and absolutely unforgivable. :madder: It makes me wonder just how much disregard some folks have for the law, and for the Highway Code, which although is only a guide, it can be used to apportion blame in a court of law, in the event of a RTC.
Regards,
Jock.
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
we are still learning
You only just have to look at how many are now coming to the market as second hand sales. Wether it be the Tribute Or Imala range or even the Apache ...Payload and Build qualitity will always be a "Thorn in the side' for Autotrail.
Shame really...they actually LOOK as if they are top quality. Until you have had one or two !
Kev
Aug 18, 2011
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
Kev
Had a new Trigano Tribute in 2008 for 4 months,,fantastic looking van,,But,,,quality poor..BUSBY.
Jul 5, 2013
11,726
13,705
Since 2013
I’m sorry I have come across as not taking advice I can assure you I am taking it onboard
And will get it out for spring ?
Probably best to buy now. In the spring they all go up in price as the warmer weather entices buyers out. There may still be some good discounts on unsold 2019 stock as the dealer needs to make space on the forecourt for the 2020 stock which is arriving now. Especially if you have your heart set on an Autotrail.
Lenny HB
53,430
149,981
Hymer B678 DL
Wake up Peter he bought it last July.
Hope you are not leaving it standing for months, the worse thing you can do with a van.
If you are not using it take it for at least a 20 mile drive every few weeks.
