battery problems (1 Viewer)
Oct 30, 2020
16
scarborough
just looking
newbie
hi can someone help, i have a sundance 630 g , while charging at home on ehu, leisure battery saying 14.5 v , and cab battery 12,1 v. On the control panel above the door there is an icon that looks like the ehu is charging the leisure battery , Does anyone know if it charges the van battery too? or do u need to switch something to alternate between the two?i have no clue,as usual!Van wouldnt start yesterday ,was trying to but thought needed battery charging up as hasnt been used in 2 weeks .Any helpful advice woulkd be appreciated ,thanks xx
Dec 2, 2019
3,587
7,774
Amersham
van conversion
Since 2019
If the cab Battery reads 12,1v it’s not getting a charge for sure. I can’t help with your model weather a has a switch and the hardware built in already to do that, or you need a additional battery master to trickle charge the cab battery. Somebody may know about your model.
1,923
8,510
North East Riviera
Low profile
Enough to Survive
It definitely doesn’t sound like it’s charging the cab battery.
Maybe someone will be able to answer for the specific control panel if you post pictures or it’s make and model.
Possibly a Sargent ECxxx unit and controller?
Wikky
342
664
Cambridge
Rapido 7065+
Since 2003
Is there a fuse in line with the cab battery as it doesn't seem to be charging?
1,923
8,510
North East Riviera
Low profile
Enough to Survive
Before you start searching for fuses, you need to find out if your controller can charge the cab battery. (Some can’t or don’t)
That image is showing the hab battery.
Can you select which battery is shown on your controller?
What controller etc is it?
W
Oct 30, 2020
16
scarborough
just looking
newbie
I don't think so. If its just the middle button on console it goes from showing levels of water in the tanks, then the pic of both battery levels, and then the last pic of just hab battery. If you press it again it goes back to the clock? Xx
1,923
8,510
North East Riviera
Low profile
Enough to Survive
See if you can find the model of the controller.....
If it doesn’t charge the cab battery, you’ll need as Raul said, a Battery Master or CBE CSB2 battery maintaining device fitting, to send a small charge to the cab battery too.
W
Oct 30, 2020
16
scarborough
just looking
newbie
The control panel is a NE 183 mate. Thanks for your advice I shall look into it further. Xxx think I need a crash course in motorhome use!!! 😉Xx
Tombola
4,833
15,710
Merseyside
Rapido 8094DF
Since 2004
if you press this does it not change to cab charging (circled below)
W
Oct 30, 2020
16
scarborough
just looking
newbie
I thought that was in an emergency to run from the van battery in case of leisure battery failure, but I may be wrong!! Plus its a NE 183 mate. Not mate, ha ha think I need a course on typing too! Xx
1,923
8,510
North East Riviera
Low profile
Enough to Survive
If you select the cab battery as your power source (not recommended when in use) as you know and plug in the EHU, test to see if the cab battery gets the charge instead.
You‘ll soon see if you use a multi meter on the cab battery.
It could be when the cab battery is online for ‘emergency’ use...it also receives the charge from the EHU.
TR5
Apr 30, 2008
160
191
West Berkshire
That's how it works on many Sargent controllers. The battery selected to provide the 12v also receives the charge. Later Sargent units auto-change (smart charging) between the batteries. If that doesn't work, then fitting a Battery Master is the best (and cheapest) option.
